M42 Overheated...No start (with video)
  • roguetoaster
    Biggus Tippus
    • 7830
    #31
    Originally posted by Vivek
    In all likelihood, if the heads cracked, I may just swap in a new engine. A new head would be 1-200, if I can find one. Then probably a hundred at a machine shop to get it resurfaced, and easily 200 for the headgasket and other seals and gaskets for it. At that point I'd be into it more than the price of a new m42. And I can source one from a friend locally who's swapping his so I know the history and mileage on the engine, and I've driven the car and it's always felt stronger than my m42.
    If it's simply a matter of cost then by all means go for a new used engine, but if you can afford it a refreshed M42 top end/timing components/water pump should be reliable for years. Anyway, with some thought before hand you can easily take the M42 out and replace it in under 2.5 hours. Whereas you might be that long just getting the exhaust manifold off of the damaged cylinder head!
    • Dj Buttchug
      • Jun 2010
      • 7686
      #32
      the cheapest I could do a hg and top end job with new valve seats gaskets ect was around 400 some bucks.
      kinda a sucky situation. GL OP
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Vivek
        attention whore/retard/bitch
        • 6167
        #33
        Thanks. I can get a new engine and tranny for 350. I'll probably just end up doing that, just want to confirm that the bubbles in the radiator are combustion gases, although everything clearly points to that being the case. Also, do you know why the hose on the exhaust side of the thermostat housing would be cold even though the temp gauge is reading halfway or higher? I've also wanted to pull my engine out for a while to clean up my bay and my trans leaks (along with my engine from the oil filter housing and some other places). Oh well, it'll be a good time to get some stuff done and clean up my bay, also swap my steering rack with the e36 one I've been putting off for a while.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • bmwman91
          • Oct 2004
          • 3134
          #34
          The passenger side radiator hose is going to feel considerably cooler than the driver's side one because it is the outlet from the radiator...it is the coolant that has been cooled off.
          Transaction Feedback: LINK
          • kwill22
            • Apr 2009
            • 962
            #35
            100 bucks is high for just resurfacing. Is that Cali markup?
            If you swap engines. Still search for a head and build an M42 turbo!!!!
            DENY IGNORANCE!
            Schwarz 325-totaled
            brilliantrot 318i-daily
            Originally posted by mkcman17
            don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
            • kkamakasi
              • Sep 2009
              • 202
              #36
              Any updates on this OP?? Did you replace t-stat? Did it help?
              • chodedub
                • May 2013
                • 56
                #37
                I'm having the same issue with my 91 318 m42, po overheated the engine felt it bog passing a semi then pulled over shut it down. Did a dry compression test with similar results as u then a dry one again with similar results. So I now have a winter project, rebuilding the motor as does my body shop owner friend the body. If all goes well I will be on the road this spring early summer, then next winter rebuild again for BOOST!!!
                • kwill22
                  • Apr 2009
                  • 962
                  #38
                  Make it happen
                  DENY IGNORANCE!
                  Schwarz 325-totaled
                  • Vivek
                    • 6167
                    #39
                    No real updates yet. Basically waiting for an engine from Steven on this forum. I also recently hurt myself in a motorcycle accident so working on my car just hasn't been happening with me being in bed for the past week.
                    • kwill22
                      • Apr 2009
                      • 962
                      #40
                      Would've never happened if the M42 was running. Lol
                      Get well soon
                      DENY IGNORANCE!
                      Schwarz 325-totaled
