Stronger pressure plate-what to use
  • brads2002
    • Nov 2005
    • 2688
    Now that I have the turbo set up the clutch is slipping easily in 3rd and 4th. I have a JB flywheel with stock clutch components. Is there a stronger pressure plate I can bolt on with out replacing everything else? The other parts are fairly new so I would rather avoid buying a complete kit.
    Happy Thanksgiving
    Brad
  • TobyB
    • 5286
    Hmm- stock M42 or stock 325? The 325 p-p is pretty grabby, and if you add a
    more- aggressive friction disc, you might be O.k. Ireland sells several more aggressive
    discs with springs in the center section...
    t
    • brads2002
      • Nov 2005
      • 2688
      Its a stock M42 pressure plate and disk. Are they interchangeable with the m20? If so, are the M20's any stronger?
      • Dj Buttchug
        • Jun 2010
        • 7686
        they are not. You cant run an m20 pp on a m42 fly.
        If the jb fly is m42 specific im pretty sure you have to run a better m42 clutch.
        I think clutchnet.com has some options for the m42.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • brads2002
          • Nov 2005
          • 2688
          Thanks DJ, looks like they have some options. I need to call and find out what the different stages mean. What do you run on your car?
