M42 running VERY loud (video), low oil pressure light is on
  • kwill22
    • Apr 2009
    • 962
    #61
    Basically yea that's it. Just need the grease or oil thick enough to do the job.
    DENY IGNORANCE!
    Schwarz 325-totaled
    brilliantrot 318i-daily
    Originally posted by mkcman17
    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
    • Vivek
      attention whore/retard/bitch
      • 6167
      #62
      So if I pour some oil in my oil filter housing and start it, it may work? Or will I have to pull the filter housing?
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • jntar
        • 459
        #63
        Pack oil pickup with Vaseline.
        M42 turbo build.
        http://www.r3vlimited.com/board/showthread.php?t=301330
        • bmwman91
          • Oct 2004
          • 3134
          #64
          I honestly cannot remember if there is a check valve in the filter housing where the oil comes in from the pump. If there is no valve, then you should be able to pull the filter element and pour some oil in to get things primed. Try it, and if pressure does not start building within 5 seconds shut it off. Maybe someone else can chime in about whether or not there is a check valve after the pump (I don't believe so).
          Transaction Feedback: LINK
          • bmwm42
            • 6300
            #65
            There isn't the only valve is the oil relief one
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • bmwman91
              • Oct 2004
              • 3134
              #66
              Cool, must have been thinking of the little spring-loaded filter bypass between the dirty and clean sides.
              • Vivek
                • 6167
                #67
                Okay so remove oil filter cap, remove oil filter, pour oil in there (how much, and any specific spot it should go?), replace filter and cap, start it up?
                • Vivek
                  • 6167
                  #68
                  Okay I poured probably most of a quart into the oil filter housing, with the filter in place. The filter was previously 100% dry. I poured it all around the outside, not inside the hole in the center. Is that bad? When i started it up, it was the same issue as always, but I'm thinking maybe I needed to pour it in the center (see pic for reference)? Anyways, I just pulled my alternator and was about to pull the filter housing to check if there's anything wrong with the gasket behind it. If it's as simple as pouring oil down the center, I'll try that. Would my car run fine with no alt? It'll be hooked up to another car to jump it.
                  • kwill22
                    • Apr 2009
                    • 962
                    #69
                    Yea I have no idea which way it flows. I would assume it flows out through the tube and goes through the filter the to the outside part of the housing where you poured the oil. So I'm thinking yea the tube.
                    If you get oil to start moving via the pump but it won't build pressure, usually the oils not thick enough. Which is why some type of grease is best. Or like juntr said earlier vasoline, but you'd have to go through the timing case for that to do it correctly and I don't think that's an option right now considering you just put everything back in.
                    It'd be nice if there was some way to crank while you're pouring the oil. But that would get real messy, real fast
                    DENY IGNORANCE!
                    Schwarz 325-totaled
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      #70
                      Maybe heat whatever grease you might use and make it easier to pour. Of course use it when the engine is cold so it becomes less viscous when it gets to (hopefully) the pump.
                      If you want to try to crank and pour oil you might try making an oil filter housing lid out of several layers of saran wrap, secured to the housing via tape or zip ties, stick a small funnel through it, then pour/crank.
                      • kwill22
                        • Apr 2009
                        • 962
                        #71
                        I've heard of people adding extra oil to the pan to help displace the air. Don't know if that would work in this situation. I'm just throwing out everything I can think of right now. This sucks.
                        I'd definitely say pour some down the tube because that seems the best way for the pump to build pressure and force the oil through the filter. Extra oil down that tube might help because it'll get rid of most of the air out of the oil pickup and pump
                        DENY IGNORANCE!
                        Schwarz 325-totaled
                        • Vivek
                          • 6167
                          #72
                          I just poured oil down the tube. No change :/. What grease would you guys recommend?
                          Only difference now is that mysteriously none of my cluster lights other than oil pressure, check engine, and ABS are lighting up with the key in position 2. But that may be because I don't have my alternator in.
                          • Vivek
                            • 6167
                            #73
                            Shit man I don't care how messy it gets at this point. If it's messy that means it has oil pressure. Should I try to crank while pouring oil? Should I start the car, or pull the fuel pump fuse and crank?
                            • kwill22
                              • Apr 2009
                              • 962
                              #74
                              I'd pull the fuel pump relay
                              The tricky part is that the oil pump sucks the oil through the pickup so that's why some people add extra oil so there's less air between the pickup and the pump. If there's too much air, the pump can't build suction to suck the oil through the pickup.
                              Don't know if you have any extra oil around. I still think some grease or something as thick is gonna be your best bet. Do you have any assembly lube? To tell you the truth at this point I don't think there's any grease that would hurt anything. Just replace your oil filter whenever it gets back going again.
                              Too bad you're on the other side of the country. I'm more hands on and I wanna help. Lol
                              DENY IGNORANCE!
                              Schwarz 325-totaled
                              • Vivek
                                • 6167
                                #75
                                Honestly at this point I think the oil pump is somehow dead. Does anyone have a DIY for it? i can't find any solid info anywhere.
