M42 running VERY loud (video), low oil pressure light is on
  • Vivek
    attention whore/retard/bitch
    • 6167
    #106
    Where could I borrow a pump from? Is it like a powered spinning pump or just like a gun type thing like for grease? I just ordered the parts I need to replace the oil pump. Also got a magnetic oil drain plug so I can see if anything collects on it. If the pump works I'll do a compression test and check the drain plug. In all honesty this car will likely get an engine swap for more power after I graduate from college, and I probably won't be driving it in college, so the engine really needs to last like 10-20k.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • bmwman91
      • Oct 2004
      • 3134
      #107
      No idea what the pump tool is or looks like, sounds like you gotta bug a couple of folks on here to find the owner.
      Transaction Feedback: LINK
      • wazzu70
        • Jan 2005
        • 1143
        #108
        Definitely try and get this engine pumping first. Everything could be fine. At least then you will know if the engine was damaged and you can work on replacing it
        -Nick
        M42 on VEMS
        • 2mAn
          Señior Mod
          • 20987
          #109
          Vivek PM me and I'll try to connect you with Kevin (Gerta)
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Vivek
            • 6167
            #110
            Any suggestions on pumping gear oil into the oil filter housing? I'm thinking get some 75w90, put it in through the oil presser sender hole. But I'd like to have a tight fit so i can pressurize it as much as possible. Maybe also turn the engine by hand while doing so?
            Any tips? Last resort before I change the pump. Parts came in today but I have no time til next week.
            • uturn
              • Dec 2010
              • 1006
              #111
              This might sound dumb so everyone chime in.... what about adding enough oil to the sump so that the level is as high as the oil pump?
              • Vivek
                • 6167
                #112
                Could try it...any cons of doing so? Any idea how much oil I'd need? There's 5 quarts in there right now.
                • bmwman91
                  • Oct 2004
                  • 3134
                  #113
                  I bet you would need like 10-15 quarts. The crank would be mostly submerged (oil pump is driven directly by the crank, meaning it is co-axial with it), and you would probably have issues with air not moving too freely under the pistons, as well as serious oil splash under the pistons that might get past the scraper rings. Not recommended both because it might not be super good for the engine, and it is big waste of $100 worth of oil.
                  • kwill22
                    • Apr 2009
                    • 962
                    #114
                    I suggested it earlier. I don't think you'd need that much to get to the pickup. I don't know how you'd measure that without taking the pan off. Once the pickup is covered pour some down the filter housing to the pump and try to crank it quickly. If not the oil would probably just flow down the pickup and displace into the oil pan
                    DENY IGNORANCE!
                    Schwarz 325-totaled
                    brilliantrot 318i-daily
                    Originally posted by mkcman17
                    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                    • bmwman91
                      • Oct 2004
                      • 3134
                      #115
                      The hole at the bottom of the pickup should be in oil if there is ~1.5Qt in the pan. 5Qt gets the level up to just over the big flat area under the crank. To fill it up to the center line of the crank (which would cover half of the pump) would definitely take a couple of gallons of oil at least. That's what I figure based on having been in there and replaced a few oil pumps anyway.
                      • Vivek
                        • 6167
                        #116
                        Okay I'll try that. I'm very busy until bimmerfest but also very anxious to get this running. A bit more motivation is that my new vanity plates are ready for pickup at the DMV but I can't get em til its smogged.
                        • Vivek
                          • 6167
                          #117
                          Well update time after 10 days off. I went down to bimmerfest then had finals.
                          Anyways, I pulled the filter housing, nothing wrong behind it other than the fact that the gasket may have been the wrong orientation. Replaced the gasket with a new one and put it on the way I felt was correct (no pics, I forgot). Then tried to prime with 80w-90 gear oil. Process was as follows:
                          Pour oil in filter housing (middle and around the outside of the inner post)
                          Let it drain a bit
                          Crank with starter while pouring oil (my mom helped)
                          Pour more oil
                          Crank more
                          (repeat for a couple min)
                          Started it up and let it run for 10ish seconds while pouring more oil in. The oil got bubbly and started to slowly rise and overflow. Oil pressure light stayed on and the timing chain still rattled like a motherfucker, so basically it didn't do jack shit.
                          Couple points that may or may not have affected things:
                          The dipstick and tube were out, I didn't realize until after
                          The two bolts in the middle of my oil filter housing snapped. The first one when I first put it on with a shitty torque wrench, the second one just now. It was probably weakened because the second it tightened down it just popped. It still has 4 of the 6 bolts in place. I tried drilling out the previously snapped one but my left handed bit wouldn't catch.
                          Time to say fuck it and get a new motor, or prime it in a different way? I have the parts to replace the pump but I doubt it'll work.
                          • e304me
                            • Feb 2006
                            • 1374
                            #118
                            Slowly rise and overflow where?
                            • kwill22
                              • Apr 2009
                              • 962
                              #119
                              Bubbles mean it's moving air mixed with oil so it was trying to prime. (Where the grease would come in) that's a good sign because at least you narrow it down to the pump gears or just bit enough viscosity to prime.
                              The only thing that would affect the pumping is if it wasn't sealed at the pickup tube. Anything that's loose after the pump wouldn't affect it priming. It'd just pump oil out of all the places that are loose.
                              And as said above where was it rising and overflowing from?
                              Other than trying it again. I'f you don't plan on sending the new pump back I'd say just install it because if you try priming again and you get bubbles you need grease to limit the air getting in. BUT at that point you'd already have just about everything off to replace the pump so I'll leave that up to you. If it were me I'd just replace it IF you can't get it to prime, but bubbles is a sign of progress.
                              random question: what diameter hose are you running from their intake boot to the ICV? I need a smaller I.D. hose and was just wondering what was working for you.
                              DENY IGNORANCE!
                              Schwarz 325-totaled
                              • Vivek
                                • 6167
                                #120
                                Out of the oil filter housing.
                                Oh damn, thanks for the good news. I'll try priming it again either today or tomorrow. There shouldn't be any leaks around the pump that it could pump oil from.
                                I believe my hose is 15/16" but I'd have to look again. If bubbling is progress I'll try it again. Crank while pouring for a while and maybe it'll eventually work.
