M42 running VERY loud (video), low oil pressure light is on
  • kwill22
    • Apr 2009
    • 962
    #121
    Make sure you keep the top end and chain lubed
    Sorry about the size. For reference this is what I've used in hydro pumps to pack the gears.
    DENY IGNORANCE!
    Schwarz 325-totaled
    brilliantrot 318i-daily
    Originally posted by mkcman17
    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
    • Vivek
      attention whore/retard/bitch
      • 6167
      #122
      So do I prime the pump with that stuff? Where exactly do I put it in?
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • LJ851
        • 7919
        #123
        Is this your first time ?
        Lorin
        The M30 is God's engine.
        • Vivek
          • 6167
          #124
          Yes . I'm Just wondering if it's thin enough to put down the oil filter housing or if I have to take the housing off then somehow force it into the pump.
          • e304me
            • Feb 2006
            • 1374
            #125
            Well if it was pumping up the oil filter housing that means it should be primed. did you try cranking it after you put the filter housing cap back on?
            • kwill22
              • Apr 2009
              • 962
              #126
              That's what you would put into the pump gears. That's why I said it would probably be easier to replace the pump because you'd have to take the timing case off to get to the pump.
              DENY IGNORANCE!
              Schwarz 325-totaled
              • Vivek
                • 6167
                #127
                No, could that be my problem? I had the cap off and filter out the whole time.
                • Vivek
                  • 6167
                  #128
                  Well holy balls I think I actually fixed it. This thing was a bitch to prime. I eventually got it to work when I primed with gear oil, cranked, put on my oil filter cap, started it, and within 5 seconds the oil light went off and the timing chain quieted down. I suppose it's finally working.
                  • brads2002
                    • Nov 2005
                    • 2688
                    #129
                    Awesome, i actually had this happen on a friends M42 a few years back. We gave up and swapped the motor. Glad you didn't. Great news!
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      #130
                      Way to stick with it, congratulations!
                      • JinormusJ
                        • 6887
                        #131
                        Originally posted by bmwman91
                        The following animation should explain how to put oil down the pump outlet and what to look for.
                        I have never lol'd so hard...
                        In my life..
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #132
                          Glad to hear you got it fixed!
                          -Nick
                          M42 on VEMS
                          • e304me
                            • Feb 2006
                            • 1374
                            #133
                            Not having the cap on after oil started to pump was your problem. If I were you I would change the oil right now and inspect it. Also look though the oil cap hole with a flashlight at the cams.
                            • bmwman91
                              • Oct 2004
                              • 3134
                              #134
                              Hey, great news! I have never ever heard of such a ridiculous ordeal involving priming an oil pump, although it sounds like a few others have. Glad it is running. I recommend pulling the valve cover and giving things a look. Also, get yourself a magnetic oil drain plug ASAP, they are very handy for collecting iron tidbits and keeping them out of circulation. Turner Motorsport sells them, and probably other places.
                              And at least you know that your bypass valve is now fresh and of the current design. I still say think about replacing the oil pump at some point, but maybe relax and drive it for a while before embarking on another adventure. At that point, I'd say to swap in a later M42 case or M44 case without the idler sprocket. Anyway, I know that more wrenching project are the LAST thing on your mind now so go enjoy the car!
                              Transaction Feedback: LINK
                              • Vivek
                                • 6167
                                #135
                                I did that yesterday before it got oil pressure and the lobe I can see is actually in excellent condition. I'm gonna change the oil immediately since it has like 6 quarts and some gear oil. Should I also change the filter because it got gear oil on it? And I agree, when I primed it the other day and it started to overflow, it was probably primed then. Then when I put the cap on it could actually build pressure.
                                I actually have a magnetic drain plug ready to go on. Any tips on what I should do with the oil that's in it? It's about a quart of gear oil and 5 quarts of castrol 20w50. Should I run it for a couple minutes to maybe get it to flow throughout the engine and remove any metal deposits, or replace it immediately?
                                Also thanks for all the encouragement guys. I just have a few things to button up on my car and it should be driving after this weekend.
