M42 Overheating
  • Aufbau Principle
    • Jan 2013
    • 121
    Right, new thermostat housing is in, no leaks. Flushed the block with a hose as well. Both radiator hoses now get warm/hot when the temp gauge is in the middle. Steam now comes out of the bleeder screw when the gauge moves past middle. Is there anything left to do other than bleed it?
    • bmwman91
      • Oct 2004
      • 3130
      Fill it up and bleed it. Set the heater to full-heat and max blower speed to ensure that the valve is open. When you put the thermostat housing on I assume that you noticed the little bypass groove between the inlet/outlet? With that clean and clear, you'll probably get 90% of the air out in the first 15 seconds after starting it (I have heard it make a whistling noise as air is rushed out). If it is blocked, no biggie, just run it until it is warmed up and then open the bleed screw. When you hold it at ~3000RPM and no more air bubbles come out, you are done!
      Transaction Feedback: LINK
      • Aufbau Principle
        • Jan 2013
        • 121
        Funny stuff today. Got it seemingly bled, started up, came up to temp in the center and stayed there. Took a few victory laps around the block for ~20 minutes with no hood on and pulled back into my driveway. Spent a few minutes cleaning out the garage when I look outside and see coolant pissing out of the car again. The lower rad hose got blown off slightly and was bubbling out of there. Loosened the bleed screw to relieve pressure and steam comes hissing out of there. Let the car cool down a bit, reattached the hose, tightened all my clamps, refilled coolant, bled some more bubbles out, try again. This time, coolant forces its way out from under the expansion tank cap when it comes up to temp if I have the bleed screw shut. The cap seems to be missing an o-ring according to pictures of them so I ordered one. Also getting a new bleed screw because the one I have is bent.
        In other news, my speedometer stopped working. It occasionally reads ~20 mph if I smack the cluster pretty hard. Other times it waves up and down between 0-20, mostly it's just stuck at the bottom. Maybe I fucked up plugging in the diff speed sensor when I did rear shocks, maybe I broke something when I jumped the car with a trickle charger after it ran out of battery.
        The mystery continues...
        • bmwman91
          • Oct 2004
          • 3130
          Damn. It sounds a little bit like the head gasket is leaking exhaust gases into your coolant system. Hopefully someone else can chime in with a less-sinister theory!
          • Aufbau Principle
            • Jan 2013
            • 121
            I'm kind of inclined to believe exhaust is leaking into the coolant as well. Drove the car for like an hour today around the block, didn't overheat but I get a bit of steam coming out around the expansion tank cap. No hose explosions this time. Hoses were hard after the car cooled down and a bunch of gas rushed out of the cap when I opened it after it cooled. Coolant level was close to the top of the tank until I burped a bunch of bubbles out of the system. Being that the car doesn't overheat and stuff isn't blowing up, how much of a ticking time bomb is the gasket? Gonna look for an antifreeze HC test kit to confirm.
            • Aufbau Principle
              • Jan 2013
              • 121
              Yup, coolant gas tester turned yellow/green when I stuck it in the expansion tank. Didn't even need an external vacuum, the gas pushed through the valve without help. Kinda looks like there's a bit of oil in the expansion tank too. Anything else to check before yanking the head?
              • bmwman91
                • Oct 2004
                • 3130
                I can't think of anything, really. It sounds like either the HG, or a crack in the head, which is somewhat common between the exhaust valves of cylinder 2 or 3. I'll cross my fingers for you that it is just the HG.
                • Aufbau Principle
                  • Jan 2013
                  • 121
                  Slowly coming apart...
                  engine (3 of 5) by AP Photomatic, on Flickr
                  engine (1 of 5) by AP Photomatic, on Flickr
                  engine (4 of 5) by AP Photomatic, on Flickr
                  Exhaust nuts are a pain. Some come off with the studs, others don't.
                  There was a fair amount of oil on spark plugs 3 and 4. Oil and water in the intake manifold. Bit of milky oil at the front of the valve cover in the timing case area. Any of those major causes of concern?
                  • bmwman91
                    • Oct 2004
                    • 3130
                    Hmmmm...maybe a just a leaky profile gasket? I don't think that would explain the over-pressure situation in the coolant system, but it could be a cause for milky oil in the timing case.
                    • Aufbau Principle
                      • Jan 2013
                      • 121
                      Fuck :(
                      crack (1 of 1) by AP Photomatic, on Flickr
                      Guess I'll take a look around and see what the going rate is for welding that or getting a new head. Gonna sell this bitch if it's more than like $200.
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Very common on the m42. Welding it is going to be expensive since that seat really needs to be R&R'd, then re-machined. Best bet is to get a used head.
                        john@m20guru.com
                        Links:
                        • bmwman91
                          • Oct 2004
                          • 3130
                          Crap, sorry to see that a crack was the cause. Good luck! M42 heads seem to be fairly cheap and common.
                          • kwill22
                            • Apr 2009
                            • 962
                            That sucks. Had the same hairline except it connected to a coolant hole. Sucks but with a little searching you can find another head quick
                            DENY IGNORANCE!
                            Schwarz 325-totaled
                            brilliantrot 318i-daily
                            Originally posted by mkcman17
                            don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                            • bmwman91
                              • Oct 2004
                              • 3130
                              No affiliation with me.
                              Low mileage M42 head for sale in Boston. Not sure how reputable the guy is, but you might be able to check it out in person.
