Oops...lol
  • jntar
    • 459
    Oops...lol
    Always something breaking lol!
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
  • bmwm42
    • 6300
    Eghhh common
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • jntar
      • 459
      Yep, had a feeling it would happen. Still trying to find the source of this rattle. All the guides look good so I guess its on to checking the rod bearings next.
      M42 turbo build.
      • bmwm42
        • 6300
        Did you check the idle gear
        • Dj Buttchug
          • Jun 2010
          • 7688
          time to bust out the propane torch
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • jntar
            • 459
            No play, all bearings there and clean. One of the first things I checked.
            Slide hammer first. Then torch if that doesn't work.
            M42 turbo build.
            • bmwm42
              • 6300
              Did you check your oil pressure?
              • jntar
                • 459
                I did not. I have a gauge and it never appeared to be low.
                M42 turbo build.
                • bmwm42
                  • 6300
                  How do you cams and tensioner look?
                  • jntar
                    • 459
                    Cams are clean and smooth. Did a head gasket less than 1k miles ago and they are exactly the same as last seen.
                    Tensioner has 15k miles on it and looks good as well. I was able to compress the oil out of it and it still extends as intended.
                    I bought a new large rail, tensioner rail, tensioner and lower guide hoping one of those were the problem. However the noise moved from the front of the head to the center of the head when I removed the valve cover.
                    You can hear the knocking while cranking.
                    M42 turbo build.
                    • bmwman91
                      • Oct 2004
                      • 3134
                      Since you are in there, take a very close look at the timing case casting around the idler sprocket. It is not uncommon to have the idler gear snap off of the boss it mounts to...happened to me, and from looking at things after the fact, I might have been able to see the crack before it broke if I had known.
                      So you replaced all of the guides and stuff and it still makes the noise?
                      Transaction Feedback: LINK
                      • jntar
                        • 459
                        Already gave the idle sprocket a good look over. Its in good shape. I did not replace the timing equipment yet. I was doing it now, but with the knocking coming from elsewhere Im holding off.
                        Picking up a hoist to hold the motor while I remove the upper pan. I want to check out the bearings before I go any further. It's not looking good.
                        M42 turbo build.
                        • glucklich21
                          • 1912
                          A pipe wrench and some turning with it will be your friend. I've had two M42s that have done the exact thing.
                          • jntar
                            • 459
                            Tried that lol! That's where the scarring on the pump housing came from
                            M42 turbo build.
                            • glucklich21
                              • 1912
                              Well damn. Time for a cheater pipe then.
