Which ignition setup are you using with MS? External Bosch quad driver? Maybe the ignition driver IC is on its way out, or the wire from MS to the driver is damaged?
Oops...lol
Originally posted by bmwman91 View PostWhich ignition setup are you using with MS? External Bosch quad driver? Maybe the ignition driver IC is on its way out, or the wire from MS to the driver is damaged?
