LSD recommendations for stock m42
  • Bizzyboy904
    • Mar 2014
    • 62
    I know there is a 4:10 lsd available for these cars, but has anyone had any different ratios that felt better with the 5 spd. This car will be a daily driver that will eventually have 16in wheels (stock 14in bottle caps now.)with a decent sized side wall if that will make any difference. te reason I want an lsd is because I am starting to do auto cross.
  • M42Power
    • Dec 2009
    • 519
    I cant tell you about lsd's but i run a 3.64 small case diff in my car and it is plenty of fun to beat on it. For auto x you have the added benefit of being able to hit 60 mph in second.
    Originally posted by kendogg
    Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
    OG RACECAR
    • G FORCE
      • Mar 2014
      • 159
      Subscribed for further info.
      Gabe
      '91 318is
      • Ocell
        • Apr 2013
        • 291
        I run a 4.1 LSD in autocross. I've never hit my rev limiter in second, but I do run out of first gear very quickly. I kind of like it because I can get my shift out of the way early. I think our course designs can be fairly fast, too. The gearing also feels decent on the couple tracks I do. It's a bit high on the highway, but it's nice to be in the power-band when I'm looking to pass someone.
        I'm running 15" wheels with 205/50R15 tires.
        Here are a couple videos where you can see my tach, if that helps.
        91 318is Members' Rides Thread
        • AndrewBird
          The Mad Scientist
          • 11898
          Wheel size will have no effect on rolling diameter. Tires are what determine your rolling diameter. If you go to a bigger wheel, you will need to have a tire with a shorter sidewall to make up for it to keep the same rolling diameter. Here is a good tool for figuring out what tire you will need:
          http://www.miata.net/garage/tirecalc.html
          • Bizzyboy904
            • Mar 2014
            • 62
            u makes i use the maths. u bad man make my head hurt!
            225/45/16 is what the calculator says is equal to my stock rolling diameter. Not wide enough to warrant the heavier wheel. I plugged in some wider wheels and it threw every thing off, I think I will just stick to 4:10 the car doesn't make power until 4k anyway.
            • jalopi
              • 2370
              For figuring out your wheel/tire package:
              Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
              For getting a good idea of what your new top speeds in each gear will be, where you'll be at in the powerband, ect when changing rears:
              • mr.vang
                • 4371
                Get a 2.73 differential and get 35+ mpg on the hwy.
                • Bizzyboy904
                  • Mar 2014
                  • 62
                  seems like i would stall out in 1st gear WOT
                  • wazzu70
                    • Jan 2005
                    • 1143
                    I couldn't imagine anything less than a 4.10 for autocross. A 4.27 would probably be even better. 3.73 is the highest gearing I would consider to get a highway cruiser/reasonable acceleration.
                    -Nick
                    M42 on VEMS
                    • Dj Buttchug
                      • Jun 2010
                      • 7686
                      yea for auto x you will want 4.10 at least. Good news is a medium case 4.10 LSD can be had pretty easily around here for like 300 bucks + or - a few.
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • TobyB
                        • 5286
                        there are 4.44 small case gearsets kicking around, too, if you REALLY like to r3v...
                        t
                        • SmokeE30
                          • 1730
                          There's also supposed to be 4.88s available as a e30m3 optional ratio
                          Shawn @ Bimmerbuddies
                          Bimmerbuddies LLC
                          717-388-1256
                          2971a Roundtop Rd, Middletown PA 17057
                          bimmerbuddiesllc@gmail.com
                          • wazzu70
                            • Jan 2005
                            • 1143
                            Yeah, its a mororsport ratio though so its incredibly expensive and rare.
                            My car has the equivalent of around a 4.44 ratio (an E36ZF and 3.73 gearset). Its a lot of fun :) I dont think there is much of a need to go steeper though.
                            -Nick
                            M42 on VEMS
                            • jntar
                              • 459
                              I prefer the 4.10. Where I live we have two autocross locations. A very small course and a very large course. The small course i never leave second gear and only on a rare occasion bounce off the limiter. The large course I do switch between second and third, but the 4.10 is still well within the power band. I run a shorter tire than stock 205/50R15, so if you're closer to stock size you'll be slightly lower in the revs, which would be good as well.
                              M42 turbo build.
                              http://www.r3vlimited.com/board/showthread.php?t=301330
