Fresh M42
  • chodedub
    • May 2013
    • 56
    Fresh M42
    So rebuilt my engine over the winter and now i finally got it running and its noisy as all heck. How loud is too loud? Any thoughts or ideas?
  • roguetoaster
    Biggus Tippus
    • 7830
    Depends on where the noise is coming from? Lifters, chain? Sure you installed the chain tensioner correctly?
    • Dj Buttchug
      • Jun 2010
      • 7688
      lifters need to pump up ?
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • chodedub
        • May 2013
        • 56
        the tensioner will only fit in the tube one way i believe, it sounds like a noisy cavilier engine. I was told about the lifters bleeding out on another site as well but how long does this take? I had the motor running for a total of maybe five mins i would think everything should be good by then? I'm nervous as hell to run it too long lol
        • TobyB
          • 5298
          When I pulled the head and freshened it, the lifters probably took 15 minutes to fully shut up.
          Sure you have oil pressure?
          t
          • FL318is
            • Sep 2006
            • 1396
            FYI. Cat back GB for the M42
            • bmwman91
              • Oct 2004
              • 3134
              r3v member Vivek had a HELL of a time getting oil pressure to build in his rebuilt M42. Although I had not heard of the issue until his escapades, apparently the oil pump needs to be primed, or packed with heavy grease before reassembly (fills in all the little air gaps which allows it to build suction to pull oil up from the pan).
              Did you have the timing case off and take the oil pump gears out?
              Transaction Feedback: LINK
              • Vivek
                attention whore/retard/bitch
                • 6167
                DO NOT start or run the engine until you can confirm that oil is circulating. You haven't given much of a description of the noise, so it's really hard for anyone on here to help you. A video would help. Here's a few questions off the top of my head that will help everyone help you.
                Did you install your timing chain tensioner uncompressed?
                Was your oil pressure light on?
                Is the noise coming from the head (like lifters/valves) or more from the front of the engine?
                Is your timing set 100% correctly?
                Are all plugs firing?
                Wish you the best, this engine can be a fickle bitch, trust me
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • chodedub
                  • May 2013
                  • 56
                  no the tensioner was uncompressed, i took the valve cover off and pulled the fuel pump relay and rolled it over as i did it seemed as tho the oil was moving around as it should, as for the oil light im not sure what on this dash works properly as there arte a few things the PO has painted over. The only description i can give of the noise is an old chev cavilier with a noisey engine. Othern then the noise the motor is running smooth i drove it round the yard a bit just to see.
                  • chodedub
                    • May 2013
                    • 56
                    BMWman no i did not, the whole front assembly including the oil pump only had 400 kms on it when i rebuilt the motor i didn't think there was need to touch it
                    • chodedub
                      • May 2013
                      • 56
                      So i found the problem and it was a goof on my part, i put the lifter trays in on the wrong sides... Needless to say im in need of a whole new top end now....thanks for the help tho guy muchly appreciated and if anyone has any m42 parts kicking around that wanna send them my way that would be muchly appreciated as well lol cheers
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Ah, drat, you got caught up in the whole "E" must mean exhaust thing.
                        • bmwman91
                          • Oct 2004
                          • 3134
                          Crap. So are your valves bent up from kissing pistons? The M42 is reasonably tolerant of that...I put the timing chain assembly back together with the cams off by 2 teeth back in 2006 or so and drove the thing for like 10 minutes thinking that the noise was dry lifters. Once I fixed the timing, it ran fine and had full compression, despite the noise I was hearing being from valves and pistons hitting!
                          • roguetoaster
                            Biggus Tippus
                            • 7830
                            I too have cranked my car and tapped valves with pistons, still working fine, but I shut it down right away. Don't assume you need to replace the whole top end just yet.
                            • chodedub
                              • May 2013
                              • 56
                              Sorry for the late update,I got lucky and just marred the cams and didnt hurt anything else.I recently purchased a 318ti donor car and have stripped the cams lifter trays and lifters from the car. Currently awaiting delivery of heat bolts and intake gaskets for reassembly . Also from the same place as i got the Ti i swipped a 74 2002, may be a m42 swap in its near future, as a side note i purchased both vehicles for $400 Can
