M42 won't hold idle UPDATE: New problem. Need help
  • jdt10768
    • Feb 2013
    • 484
    I would not soak the entire ICV. Just spray a bunch through it both ways. Tap it a few times all around and spray again. Install and test.
    • shameson
      • Jun 2012
      • 1507
      Really? Hmm I've heard soaking it is the trick. I'll just spray it then
      Did get a spare fuel pump so will do that after doing the fuel filter this weekend
      '84 Alpine 325e (Gone)
      '91 Alpine 318i (Gone) Click Here
      '92 Alpine 325i Cabrio (Gone) Click Here
      '91 Alpine 318is
      • bmwm42
        • 6300
        Jaime, have you checked to make sure the harmonic balancer isnt falling apart......if the thing is becoming undone your never going to hold idle. Ive had a car do that before. Anyways you have my number if you need further assistance.
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • shameson
          • Jun 2012
          • 1507
          That's an interesting idea...but wouldn't it not run altogether with a failed balancer?
          And thanks, if none of the this stuff works I'll have to pick your brain
          '91 Alpine 318is
          • bmwm42
            • 6300
            It actually will which is why when you give it gas it doesn't die. It's quite simple just look at your harmonic balancer...... worst case scenario you fried the ecu when changing the alternator.
            • shameson
              • Jun 2012
              • 1507
              I tried a spare ecu to be sure, no change
              '91 Alpine 318is
              • amit_b82
                • May 2014
                • 7
                Before you go around messing with the fuel pump, I would take out the ICV. Mine had 2 contacts. Apply 12V to it and you should hear a click. If not, it is bad. My car was doing the same thing. I ended up getting a used one off of eBay for $35. That fixed my problem. Make sure it clicks before installing. Keep us updated.
                • shameson
                  • Jun 2012
                  • 1507
                  I'm going to borrow an ICV that's in good order off a friends if I need it
                  See post #1 for new update
                  '91 Alpine 318is
                  • shameson
                    • Jun 2012
                    • 1507
                    So yesterday I tried a different ICV, AFM and ecu. Even cleaned my own ICV too. It would fire up fine after sitting, idle fine, and rev up fine, with no missing. But then it would die after a minute or two of running. Once it would die it wouldn't stay idling that long and would start missing at ~ 3500-4000 again. After dying it would cause hard starting, and would barely start again.
                    Still kinda lost at this point, next thing is that I'm going to give the injectors a cleaning, and hopefully see if I can find out if they are flooding it maybe, causing it to run too rich
                    Tried it again today and wouldn't even idle. Would die instantly every time
                    '91 Alpine 318is
                    • jrobie79
                      • Mar 2006
                      • 2526
                      make sure the connector on the passenger side firewall is disconnected? you may have inadvertently connected it if you noticed it wasn't before
                      1991 318i ---- 308K - retired
                      • shameson
                        • Jun 2012
                        • 1507
                        Nope, never touched that plug prior to this. I wish it was that simple lol
                        '91 Alpine 318is
                        • mjimport
                          • Jan 2010
                          • 418
                          Any update on your progress?
                          • shameson
                            • Jun 2012
                            • 1507
                            So far no. Drained the fuel tank in case I had bad gas, like water in it. Going to fill up a can of fresh premium and put it in. After talking to others, going to check ground straps next, see if there's a bad ground causing the issue. Part of me does think this is a electronics/power related issue. Still haven't ran the compression test which I will and also having someone come up to help troubleshoot soon.
                            '91 Alpine 318is
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3424
                              The failure of the alternator coinciding with this problem may be a red herring. Here are some things you haven't checked by my reading of your thread:
                              Ignition Timing
                              Fuel pressure
                              Fuel injector o-rings
                              Fuel injector spray pattern (pull the rail out and watch the injectors fire while you have someone crank it, with the coil unplugged)
                              Intake manifold gaskets, tightness of manifold nuts
                              Brake booster valve and booster itself (can cause vacuum leaks)
                              Ground on the battery tray near the firewall (this is the ECU's ground and is important)
                              AFM connections and condition of wiring/connectors and pins
                              I recommend putting a couple of gallons of new gas in it then checking these things if the problem doesn't go away. They're all pretty easy to check. If you block the ICV off and prop the throttle open a tiny bit you will be able to eliminate that as a source of problems altogether so it's easy to diagnose. Also verify proper charging system voltage to eliminate the new alternator as a problem, I have seen bad alternator regulators cause very high system voltages and odd problems.
                              IG @turbovarg
                              '91 318is, M20 turbo
                              • shameson
                                • Jun 2012
                                • 1507
                                Sweet, thanks for your input. This gives me a lot of leads to follow up on. The alternator check is a good idea, makes me curious if my new alternator really is the problem all along
                                '91 Alpine 318is
