M42 high idle after throttle body heater delete
  • and_e30
    • Oct 2014
    • 94
    #61
    i picked up a throttle position sensor off an e36 318 ti at the junk yard, exact same part number. after installation stomp test still doesn't work and the car drives the same.
    what else could cause the stomp test to fail? running out of ideas.
    1991 E30 318is - Project car
    1995 E36 M3 - Impulse buy
    1998 E36 M3 - Weekend car
    2002 E46 325i - Daily
    1991 E30 325i - Sold
    2003 E39 540i Msport - Sold
    • AndrewBird
      The Mad Scientist
      • 11898
      #62
      You need to verify the TPS is working correctly ON THE CAR. There is a little bit of play and adjustment, not to mention something else could be keeping the throttle from closing all the way and/or opening all the way.
      • and_e30
        • Oct 2014
        • 94
        #63
        Isn't driving it around verifying it is working while on the car?
        From what I can see there is zero adjustment, it is a dummy proof alignment on the pin by having a flat spot, so it can only align one way. I also took off the intake boot and verified that the throttle is opening and closing properly when the throttle is being moved.
        • uturn
          • Dec 2010
          • 997
          #64
          Confirm the throttle body studs are not stripped at the manifold? Or the nuts bottoming out? BMW used shorter studs before they did the recall with the heater plate.
          Also, I did the fuel injector rebuild on mine and they all leaked by because I used aftermarket kits instead of ordering the orings from bmw. Do the smoke test or spray throttle body cleaner and see if the revs increase to rule out the vacuum leak theory. The three sensor wires were confusing for me but was lucky and got them right. Check to make sure you didn't mix the engine temp with the oil pressure one.
          • AndrewBird
            The Mad Scientist
            • 11898
            #65
            The engine will still run with it not working. Driving the car does nothing. You need to check it with an ohm meter or a continuity tester. Checking if the throttle plate opens/closes all the way tells you nothing about the tps.
            Seriously, this isn't that hard.
            • and_e30
              • Oct 2014
              • 94
              #66
              tested the tps terminals at 1 and 3 to get 4k ohms and also the tps terminals at 1 and 2 and rotated the throttle from idle to full position and had a range of 1 - 4k ohms respectively. both these numbers match the bentley book.
              tps seems to be working within spec.
              • and_e30
                • Oct 2014
                • 94
                #67
                I took the boot off the tps harness as someone mentioned in a previous post. Sure enough the ground wire was broken off. I spliced in a whole new connector and there was a huge difference. The car drives a lot better, much more responsive in the mid range. Also, the check engine light went off. These are all good things.
                When I start the car up, it idles around 700 like it should. But after driving it around for 20 min or so the idles hover around 1k and don't drop. I probably put 50 miles on the car since the new connector and the issue still exists.
                I notice when I drive it around and the idles are high at 1k, if I unplug the tps harness the idles drop back down to 700 and once I plug it back in the rpms maintain normal until I drive it again.
                Do these symptoms sound common to any problems you guys have experienced?
                • roguetoaster
                  Biggus Tippus
                  • 7829
                  #68
                  Yes, called it. I had the same issue on my car early last year, mine was slightly lower in the loom. Solder, splice or replace the pin connector as appropriate.
                  • dude8383
                    • Jan 2005
                    • 10387
                    #69
                    Check for continuity on each wire there. maybe you have a break someplace else?
                    • uturn
                      • Dec 2010
                      • 997
                      #70
                      A friend had an issue with a bad afm, installed a good one but no improvements until he pulled the battery and reset the computer. Maybe do this to clear the tps fault code?
                      • and_e30
                        • Oct 2014
                        • 94
                        #71
                        Not getting a fault code anymore and I have heard mixed knowledge on the battery unplugging actually resetting the computer. I guess it's worth another shot.
                        • Stevoyayaya3
                          • Aug 2013
                          • 315
                          #72
                          This happenened to me once after I did my mess. It only did it for about 5 mins then I started the car over and it stopped lol. Just love these little problems lol
