Spare M42 refresh/rebuild
  • fresh_TD
    • Aug 2013
    • 2457
    Today I finished disassembly, and did some more cleaning. Cylinder walls still look good on the block, cross marks are still there.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • uturn
      • Dec 2010
      • 1001
      Close up of the head where the profile gasket sits under the waterpump....
      • fresh_TD
        • Aug 2013
        • 2457
        I'll snap a picture this afternoon when I leave work.
        • fresh_TD
          • Aug 2013
          • 2457
          E36 M42 timing case came in today:-) Also did some more cleaning. .now on the hunt for an M47d crank.
          • ccsdo5
            • Mar 2013
            • 707
            Going for a 2.0L turbo build eh? I thought about doing that once, sub'd.
            -Dee
            5-lugged turbo 318is Barn car
            IG: @deebelmont
            • fresh_TD
              • Aug 2013
              • 2457
              That's the plan. I will run it NA for a while before I go turbo
              • roguetoaster
                Biggus Tippus
                • 7830
                JakeB kit planned or something else?
                • fresh_TD
                  • Aug 2013
                  • 2457
                  Jakes kit
                  • fresh_TD
                    • Aug 2013
                    • 2457
                    Didn't work on it this weekend. Today I finally fished disassembly..will start looking around for a good machine shop in the northern VA area, any suggestions? that will do the boring on the block to 86.4mm to fit the S52b32 pistons.. CR target is 11.5:1 decking the pistons will be necessary. Oh and the VW lifters came in.
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      Small update: dropped off head at the machine shop yesterday, to get cleaned and get pressure tested, etc. Found a set of S52 pistons. They should be in by monday, and can finally take the block to get cleaned, bored and honed. While I wait, I'm starting to clean, paint, and clear parts to make the engine look clean.
                      • DER E30
                        • Sep 2013
                        • 2347
                        Schwing this is gonna look soooo good
                        -Christian
                        • The White Guy
                          • Jul 2012
                          • 144
                          You are making me jealous ;)
                          This is what I would like to do to my M42.
                          Glad to see another M42 build. sub'd
                          Wise choice with the late M42 timing cover.
                          • fresh_TD
                            • Aug 2013
                            • 2457
                            Thanks. S52b32 pistons should be waiting for me when I get home from work today, and the M47 crank should be in by Friday, hopefully.
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              If you don't mind sharing, what's an M47 crank going for now?
                              • fresh_TD
                                • Aug 2013
                                • 2457
                                From dealer about $1100 for a refurbished one with bearings.. used ones start right around $500 and up.. the Problem is finding a used crank.. they're not easily available
