Any supercharged E30s out there?
  • bflan2001
    • Sep 2007
    • 65
    I'm considering forced induction and am leaning toward a supercharger. I've never been a huge fan of turbo lag, and I don't want to deal with all the intercooler piping involved. I've seen supercharger 'kits' for the E36 but they specifically say that the kit won't fit an E30. I'm not too worried about making a bracket, and since I'm not running PS or AC I have plenty of room for it.
  • Streichholzschächtelchen
    • Jan 2009
    • 1670
    Steffou on youtube. M30 eaton m90, the route i am going.
    Jah bless! :pimp:
    • bflan2001
      • Sep 2007
      • 65
      Could you post a link? I tried several different searches and couldn't find anything.
      • roguetoaster
        Biggus Tippus
        • 7820
        The kit that's out there seems to be a matter of serpentine belt conversion and mounting. Can't imagine what else you'd really need to do considering the two engines.
        However, DASC prices (generally without the tune) are about the same as a JakeB turbo kit. If you went with the latter it's a small turbo/moderate boost you won't be too laggy.
        • bflan2001
          • Sep 2007
          • 65
          So far they've only tested RHD cars, I don't think anybody knows if they'll fit the LHD setup yet. There's a lot more on the intake side of the engine bay in a LHD car. I also have a swapped E21 so my engine bay is even smaller than the E30. It sounds like I'm just going to have to go custom if I want a supercharger.
          I've considered turbo and haven't fully decided on the supercharger yet. If I did go the turbo route it would be with JakeB's kit, but I think the SC is going to end up being the better option for me.
          • bflan2001
            • Sep 2007
            • 65
            Another thing about the supercharger kit is that it uses a roots type blower. I'm looking into using a centrifugal style which should be easier to fabricate. One requires making a new intake manifold while the other just needs a simple bracket.
              • Jan 2009
              • 1670
              Here you go bud. https://www.youtube.com/watch?v=uOv8pz33Lj0
              Just takes a custom bracket, some urethane couplers n stuff. Notice the stock afm!
              Jah bless! :pimp:
              • MVincken
                • Sep 2015
                • 75
                I don´t know this is going to work properly
                because now you´re infuencing your own system
                better place that AFM before the blower imo...
                • Ether-D
                  • Sep 2011
                  • 2838
                  Centrifugal superchargers are laggy. Building an intake manifold was not that bad. There a good amount of information in my build here on r3v.
                  Long version- http://www.r3vlimited.com/board/showthread.php?t=298349
                  Short version in my sig.
                  Originally posted by Andy.B
                  I was born on 3/25…
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3354
                    If you're going centrifugal you may as well go with a small turbo like a T3 or GT25. You don't get the instantaneous, linear response of a positive displacement supercharger with a centrifugal unit. There is no "lag" with a centrifugal supercharger but it doesn't build boost down low, much like a turbo.
                    IG @turbovarg
                    '91 318is, M20 turbo
                    • yourmightyruler
                      • Mar 2014
                      • 24
                      I inquired a couple months back, they have had success fitting the supercharger to LHD M42's.
