Water leak?
  • sketchkid
    • Dec 2015
    • 165
    Water leak?
    So I brought a 318is 2days ago this is really my first time working on a car, the previous owner told me there was a water leak and I've taken picture of it, what holes is this pic below
    91 318is "under construction"
    2007 328i - daily
  • uturn
    • Dec 2010
    • 1005
    There was a safety recall so that hose was cut to install a bypass valve. Goes to the heater core.
    • TobyB
      • 5286
      Yup, heater hoses. If you're lucky, it's the hoses, not the adapter that mounts
      to the back of the head.
      You can delete that thermostat if you want to- it's a fix for a problem that doesn't
      affect most of us.
      www.realoem.com has pictures and diagrams and part numbers.
      www.blunttech.com has parts.
      t
      • sketchkid
        • Dec 2015
        • 165
        So I shouldn't worry about it?
        2007 328i - daily
        • TobyB
          • 5286
          You should fix it.
          Losing water is a surefire way to kill an M42
          t
