Vibration at crank pulley
  • iPee
    • Nov 2013
    • 190
    Is this too much vibration at idle? It stabilizes when under load. Any idea what could be causing this and what implications it could have?
  • e30davie
    • Apr 2016
    • 1788
    I assume M42 pulleys have the layer of rubber between the two surfaces like most.
    what you are seeing is this rubber flexing. There is probably a spec for it, but i would think if you can see it....it might be time for a new pulley?
    • bmwman91
      • Oct 2004
      • 3130
      The crank damper has a rubber ring (since it is a damper), but the rest of the pulleys bolt directly onto the crank (effectively, actually through a flange which is clamped on by the big 22mm bolt).
      It is a little hard to tell from the video, but it does look like the pulleys with the belts are wobbling. That is NOT normal. Maybe consider removing the belts and getting in there to check all of the bolts holding the pulleys.
      Transaction Feedback: LINK
      • iPee
        • Nov 2013
        • 190
        Like the pulleys for the ac, power steering, water pump, and alternator?
        • bmwman91
          • Oct 2004
          • 3130
          Yeah. Those are supposed to be rigidly fixed to the crank and should not wobble at all.
