M42 Won't Idle, Some Backfiring [EDIT: Photo Dump Of Broken Stuff]
  • bmwman91
    • Oct 2004
    • 3134
    So today as I was almost home, the car started idling very poorly, bogged and died at a stop sign. It took a lot of cranking to get it to restart, and once it did, it would bog and stumble at <500RPM, and then stall. Once it is in this mode, opening the throttle makes no difference at all, other than increasing the amount of backfiring (not a lot, but I get a few good puffs).
    If I give it throttle while cranking, it will start right up and run smoothly on all 4 cylinders above 1200RPM, with minimal backfiring. It was running nice and strong immediately prior to all of this, and I was out beating on it in the hills for fun. Now, if I can get it to rev above the idle speed, it will have a hesitation around 1500RPM, which was not there before.
    For the last couple of months, I have been noticing that the car will bog a bit at idle for about a minute after a cold start, usually not quite enough to stall, and giving it a blip of throttle usually sorted it out. I assumed it was a dirty ICV, but cleaning it made no difference.
    Stuff I do not think it is:
    - Since the car runs smoothly from 1500-3000RPM (I have not had a chance to try to rev it higher, I was just happy to limp it home), I am assuming it is NOT fuel delivery related. The injectors, pump and filter all have under 30000 miles on them.
    - AFM. There is no AFM because I am running a MAF conversion. If the converter was bad, it would not run well at any RPM.
    - TPS. I checked the voltage output in accessory mode and it varies smoothly from 0.5V to 4V throughout its range.
    - Cam position sensor. Even though the stomp test gives me code 1244, unplugging the cam sensor makes no difference. This code seems to come up for a variety of reasons other than a bad cam sensor (which is what it is supposed to indicate).
    - Cracked head. No milky oil, and the expansion tank is not overflowing.
    - Idle control valve. If it was this, opening the throttle would have an immediate effect. Again, if the car is in death-bog mode, nothing I do with the throttle makes a difference.
    - Ignition coil. It is unlikely that more than one died simultaneously, and I know what an M42 feels like running on 3 cylinders. This ain't it lol.
    My main suspicion is the crank position sensor. It is one of the few original sensors left on the engine, and I cannot think of anything else that would make the idle so bad while also causing throttle inputs to have zero effect. I measured its resistance out to be 590 Ohms, which is at the high end of the spec. God help me, the OEM ones are $232 lol (which is fine, I don't mind buying one if it the real cause!).
    Any thoughts? Am I missing anything?
    Transaction Feedback: LINK
  • TobyB
    • 5298
    I was thinking CPS, too, as I was reading...
    Just because it costs nothing, I would first check fuel pressure,
    and also all the ignition components. And remove all the
    post- maf boots and make really sure they aren't cracked/ falling off.
    And see if maybe there are any codes...
    t
    • bmwman91
      • Oct 2004
      • 3134
      I'd assume that a fuel delivery problem would mean even worse running above idle, where demand is greater? Pump, filter, injectors and regulator all have <30k miles on them.
      Ignition was a thought and I'll check the coils and plugs. If it was a bad one I'd think that it wouldn't run better at higher RPM, and there would be some response to throttle input when bogging. It's easy to do a visual though.
      Rubber stuff is fairly fresh, but I'll do a good check for vacuum leaks. Again, I'd think a vacuum leak would clear up as I open the throttle.
      If the TPS is really messed up it might cause this, but it gave good readings on the DMM.
      CODE 1244, cam position sensor. Unplugging it made no difference.
      My cousin in law is bringing his E30 by later so I can swap his sensors on one at a time, so hopefully it's a simple thing. The car started and idled fine cold this morning, which is annoying. I'll warm it up fully later to see if this issue returns.
      • roguetoaster
        Biggus Tippus
        • 7830
        This does not sound quite the same as when my vibration dampener/crank trigger wheel separated and clocked over, although it did generate a 1244 that I couldn't diagnose only to cause the car to stall/not restart after a spirited drive. So if you want to check timing agreement before buying a new crank sensor it might be worth your time.
        Hoping it's just a sensor.
        • bmwman91
          • Oct 2004
          • 3134
          Alrighty party people, I think that I have found an issue, and probably THE issue. It seems like it should explain my very recent no-run / poor-running problem, as well as some intermittent wonky idle and infrequent low-load backfiring over the last year. Also, it is going to be expensive lol.
          Things that need replacing:
          - Crankshaft damper
          - Accessory drive pulley
          - Crankshaft position sensor
          - Camshaft position sensor
          - A crank position sensor bolt with mangled head
          - Cam position o-ring
          I pulled the belly pan and fan+shroud to get a good look at things today. Initially it looked like it was an obviously failing crank position sensor since the cable sheath was totally broken and the shielding was exposed.
          The magnetic pickup head was a little dirty, but set at the correct distance from the teeth on the position wheel.
          I then took a look at the damper wheel, and thought, "well I do not believe that there is supposed to be a big circumferential gap there."
          Rotating the crank with a 27mm socket & ratchet, I noted that there was a lot of axial wobble, with the damper changing distance from the timing cover by a good ~3mm throughout its rotation.
          There also appeared to be some evidence that the back of the teeth were making slight contact with the cover.
          At this point, a number of things under the hood were clearly in need of removal, inspection and (in a week or so) replacement. I cleaned up the crank sensor and looked a little closer. While I do not think that any of the conductors were yet failed, it is only a matter of time until oil and other contamination get into the sensor body and finish it off. Additionally, the pickup face looks partially crushed, from god-only-knows what wrenching mishap in the last 13 years.
          The cam position sensor's cable sheath was also failing in a couple of spots, so it is also being replaced. I did notice the super awesome micro TIG welds holding the pickup nub to the body. I thought that those were neat.
          Next I wanted to remove the pulley drive hub to get a look around behind it. This time I was fully prepared, and no sweat was produced breaking the 250+ ft-lb bolt loose. 50" cheater-bar, custom crank locking plate & a floor jack to support the plate. No problem!
          The position wheel + pulley was only ~40% attached to the driving hub. I could open it up pretty easily by hand, and a little more coaxing by my foot got it looking like this.
          This thing is almost exactly 29 years old. It looks like it was produced in May of 1990.
          A little more light pushing by hand completed the transformation into scrap.
          I also noticed that the accessory drive pulley was a little bent up. Since the new damper wheel is ~$500, I am not going to bolt a bent thing to it (nor am I going to bother straightening it). It is getting replaced since it is simply not worth throwing the balance out or otherwise distorting the new damper drive hub.
          Also, my engine uses a slightly different crank hub bolt than the stock E30 M42. Metric mechanic built it with this monster, and I will need to call them on Monday to get the proper torque spec for it.
          You know you have been working on these things for way too long when taking the crank hub bolt off takes less than 3 minutes lol. Well, less than 3 if you don't count the trip to the hardware store for longer M8 bolts lol.
          So there it is for now. I will be ordering the necessary parts to replace this old crusty crap, and hopefully the thing runs properly thereafter. Even if it is not the root cause, this stuff obviously needed replacing anyway.
          • bmwman91
            • Oct 2004
            • 3134
            Also, just for reference, here is a shot from the factory service manual that gives expected measurement values for some of the engine sensors.
            My crank sensor measured 518 Ohms cold (~20C) and 590 Ohms on a hot engine. This makes perfect sense since the temperature coefficient for resistance of copper is ~0.393% per degree Celsius. That 72 Ohm increase would correspond to a ~35C temperature increase, or a sensor at ~55C, which seems reasonable. So you can expect the resistance value you measure on this, and other resistive sensors with copper coils, to vary with temperature.
            • bmwman91
              • Oct 2004
              • 3134
              Funny thing. After 20 years of working on these things, I can still learn something new (or, be dumb and not realize something). For whatever reason, the 240 ft-lb crank hub bolt gets referred to as the "crank damper bolt" a lot on forums. I have done 3 M42 timing case rebuilds over the years. At no point have I ever removed just the crank damper wheel on its own, but always as part of a timing case job. So basically, despite the fact that I have been through the motions and should know perfectly well that it is held on by 6 M8 bolts, I just went into auto-pilot mode and took off the big crank hub bolt since, "it's the damper bolt, it holds the damper on."
              So, despite having the 6 M8 bolts out which freed the damper wheel, I continued to break the big bolt loose. The damper was a bit stuck on the central hub and alignment pin, so maybe if it had fallen off I would have realized that I was making more work for myself!
              The crank hub seal in the lower timing case needs replacing, as I discovered. While it does not leak oil, it is sort of hard and stiff, and is not gripping the hub at all. So it is likely creating a small vacuum leak. My efforts to take the big bolt out were not totally in vain. Also, owning a tool take makes removal and installation of the big bolt a super simple affair helps to make it a couple extra minutes of work.
              In other news, I took this as an opportunity to do a bunch of stuff that I bought parts for a year ago and never got around to installing. Today I replaced the thermostat and sealed up a little oil leak where the outer profile gasket has a joint with the upper timing case and inner profile gasket. The outer profile gasket and timing case gaskets were replaced as well, and the upper timing cover properly pressed flush with the rest of the valve cover sealing surfaces on the head. The engine has been running a little cool, so the thermostat needed swapping. I also put on a new viscous unit for the main fan. Tomorrow I plan to do the fuel filter and both coolant temp sensors in the head.
              Hopefully the new damper wheel, sensors and lower timing cover shaft seal are stocked items so that they will arrive this week. They were ordered through getbmwparts.com.
              • Balleristic31
                • Aug 2009
                • 4198
                Very helpful and informative!
                Just another thing to look out for on these old M42s.
                -NICK
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  Glad you found the issue, but I feel for your car parts account.
                  That said, the dampeners went NLA a while back and they were surprisingly cheap (less than $250), so someone snapped them up. I'd expect that there are some new ones out there for not a horrible price, but right now the usual suppliers will probably list it as backordered.
                  However, it's these parts that are really making the M42 a poor ownership proposition these days, and it was a big part of my choice to not build an M42, but rather to M54 swap in future.
                  • bmwman91
                    • Oct 2004
                    • 3134
                    BMW of Silver Spring does not have any in stock, but they have one on order from Germany for me. I inquired about NLA / backorder status, and for the moment it sounds like there is a fair amount of inventory in Germany still. But yeah, I bet that a lot of M42's out there are or be in need of having this stuff replaced. These cars definitely are not getting cheaper to own!
                    And yes, the bill for this round of parts was pretty ugly lol. My order should show up in 1-2 weeks. Thankfully I usually commute to work by bike or train, so for the most part this isn't a big deal.
                    • the_thryll
                      • Jan 2013
                      • 39
                      Thanks for sharing all the details in this thread.
                      It looks like your parts order also included the OEM BMW brand crank sensor (12141721504). And so even though your parts bill may hurt, you can claim a small victory by knowing that you'll avoid the frustration I dealt with after I installed the much cheaper Bosch brand crank sensor: engine idled normal, but usually died when throttle opened.
                      • bmwman91
                        • Oct 2004
                        • 3134
                        Yeah, I actually went with the OEM one specifically because of stories I had read on here about the Bosch one being crap. Since the crank position sensor is THE single most important input to the ECU, there is no good reason to take chances with it IMO.
                        • ccsdo5
                          • Mar 2013
                          • 708
                          I wonder if this is my cars current no start issue as well. I was trying to tune my idle on megasquirt and it was basically lose sync and catch itself at idle which I thought was weird, then a couple days later I had a complete no start. Took a trigger log of the crank sensor and it gets a signal then has nothing and will then randomly pick up signal again but never starts.. I find it weird because I replaced my crank sensor with an OE BMW sensor about 2.5-3 years ago.
                          -Dee
                          5-lugged turbo 318is Barn car
                          IG: @deebelmont
                          • bmwman91
                            • Oct 2004
                            • 3134
                            It is pretty easy to tell if the damper wheel is failing if you get in there and poke around. If you see a gap between the rubber and metal surrounding, or if you can get it to deflect in the direction of the crank axis by hand, it's on its way out.
                            Removing it is also super easy since you just have to pull the belts and the 6 M8 bolts holding it to the hub.
                            • bmwman91
                              • Oct 2004
                              • 3134
                              Here's a question...is there going to be any issue if oil has dripped down onto the clamping faces of the timing chain sprocket on the crank? The crank bolt compresses the hub, sprocket and crank together super tightly and that is how all the torque is transmitted, but since it has been apart there's probably some amount of oil that has run down and into these interfaces. I REALLY don't want to have to pull the timing case covers off since that means ordering more gaskets, and having to realign the CPS holder (since I have an M44 timing case). I don't think that I ever bothered with this in the past, and I have not heard of the lower crank sprocket slipping / shearing the woodruff key. But, if there's one thing I have learned, it is to be overly paranoid lol.
