Is my LSD still salvageable
  • Highway1
    • Jan 2009
    • 773
    So i came across a killer deal on a 4.10 lsd with 130k on it. I put it in today and forgot to check the oil. I went for a test drive and it seized up on me. i got towed home and found that there was NO oil in it. My question is, is it salvageable or did I ruin a good lsd?
  • NOMAD
    • Feb 2007
    • 1502
    my vote is for ruined.
    melted and jammed up inside?
    '74 2002 - Build blog at
    nomads2002.blogspot.com
    • lennon
      • Jun 2008
      • 1416
      how do you get a part like that and not clean it all up, check seals, check fluid, etc?
        • 34827
        out of curiousity, how far did you get? just so we know how studly the E30 rear diffs are when run without fluid. :p
        • Highway1
          • Jan 2009
          • 773
          I cleaned it up checked the seals and everything looked good but I forgot to put fluid in it before the test drive.. duh!!, Wow i feel like an idiot.
          So i took the diff apart and it turns out that it's the input shaft that seized up, everything else looks undamaged. how hard would it be to change out the bearings, or can i put the LSD core in my open diff case.
          BTW i went about four blocks and then did about 3 or 4 doughnuts and drove another two blocks before it locked up on me.
          • Joe318is
            • Sep 2005
            • 6451
            lol
            if it isnt, a 373 ls is a better choice
            Originally posted by vlad
            • E30nate
              • Oct 2007
              • 1050
              you can put the lsd in the open case. thats what i did. if it does end up being FUBAR, i have a s3.73 for sale.
              • Highway1
                • Jan 2009
                • 773
                I thought of doing that but the transmission covers look different (number 4). it has 6 bolts on the LSD case and only 4 on the open diff. does that matter or did you just swap the LSD core and the output flanges?
                <a href="http://www.flickr.com/photos/travisragona/3219833284/" title="Diff by tfr85, on Flickr"><img src="http://farm4.static.flickr.com/3333/3219833284_a82c4855a2_o.png" width="592" height="419" alt="Diff" /></a>
                • Highway1
                  • Jan 2009
                  • 773
                  don't know how to post pics yet
                  • E30SPDFRK
                    • 5685
                    Sounds like a proper test drive :nice:
                    Byron
                    Leichtbau
                    • Danny
                      • 14217
                      Nate I wants your 3.73.
                      • Highway1
                        • Jan 2009
                        • 773
                        Hey thanks for the unput. I ended up putting my original back in because the cases are different sizes but i was wondering if anyone may be interested in the LSD unit? I'm sure that it could be droped into another case of the same size.
                        • rafiki
                          • 245
                          i bought my 318, and the next day checked the oil in the diff and it was empty. almost sure it hasnt had oil in it in at least 4-6 months. if not a year or more
                          • Doughnut
                            • Oct 2007
                            • 869
                            I wounder if the clutch rings are good anymore... I would think that running the unit under stress like that with no oil would burn them making them unservicable.
                            IMO that diff is a boat anchor now :-(
                            Out of curiosity is there any signs of harsh wear on the crown/pinion?
                            ///Monstrosity. (OO≡≡[][]≡≡OO)
                            Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
