Main bearing #3 toast?
  • arrayxt
    • Oct 2019
    • 18
    As I continue refreshing my M42, I got to taking my upper oil pan off to get a quick look at the general condition of the bottom end. I unfortunately saw what looks to be pieces of bearing that may have broken off on the center main bearing, however I'm not 100% sure. Here's a picture:
    Click image for larger version  Name:	P_20191216_204608_004.jpg Views:	0 Size:	74.8 KB ID:	9892599
    So the question is, should I be looking into getting new main bearings? Or am I just being paranoid? (I sure don't think so)
    I don't want to have to take the bottom end apart if I don't have to, but I will fix what needs to be fixed to get this motor running reliably. The oil I drained from the motor didn't look shiny or metallic, and I could only find what seemed to be very tiny chunks of the timing chain guides, nothing I believe to be a cause for concern, but I may be wrong. The majority of the timing chain system looks to be in decent shape, however it definitely needs a new tensioner.
  • e30davie
    • Apr 2016
    • 1788
    Pull that cap off and take another photo.
    • arrayxt
      • Oct 2019
      • 18
      I'll get a picture of it tomorrow. Do I need a torque wrench to get that cap back on and can I reuse the bolts? I don't have a lot of tools with me at the moment.
      • roguetoaster
        Biggus Tippus
        • 7830
        You absolutely want a torque wrench to reassemble. Bolts are okay to reuse.
        • arrayxt
          • Oct 2019
          • 18
          Click image for larger version  Name:	image_146849.jpg Views:	4 Size:	96.1 KB ID:	9892752 Click image for larger version  Name:	image_146850.jpg Views:	4 Size:	74.3 KB ID:	9892753
          Definitely some good damage there, not quite sure why this would happen. I pulled the other caps off as well and all the other bearings looked to be in decent shape, minus a few small marks here and there.
          • roguetoaster
            Biggus Tippus
            • 7830
            Not an expert, but that has to be contaminant damage or a blocked galley as the upper is okay. Excellent spot when you pulled the pan BTW!
            • TobyB
              • 5298
              Or oil starvation...
              The bearing is done, the crank might polish- BMW mains are hellaciously stout.
              Given how that looks, tho, time to look at all the rod bearings. #3 is the canary in this coal mine...
              t
