S6-37 Transmission swap
  • George Hill
    • Jun 2013
    • 3
    Hey everyone, I tried searching for this info, but haven't found what I am looking for.
    When swapping the S6-37 or "ZHP" trans into an E30 what are my crossmember solutions? I've seen the Kassel bracket and the Garagisitic mount extensions, but is there anything else?
    What about a shifter? It seems cutting the shift lever carrier to the correct length is not and issue, same for the selector rod, but has anyone figured out a nice lever option?
    Thanks, George
  • jbontke
    • Mar 2019
    • 449
    I bookmarked this link: https://www.r3vlimited.com/board/for...leted?t=259427
    But the guy went back and removed all the info. Geez.
    • George Hill
      • Jun 2013
      • 3
      Yep, I had found that one too and what a bummer to see all the info deleted.
      • R3Z3N
        • Jan 2011
        • 3056
        ^He used an E90 crossmember that bolts to the trans. You still need a custom solution to bolt to the chassis with your choice of trans bushings:
        BMW # 22-31-6-796-993
        In my E30 S54 build, I was running out of time and just used the Kassel brace. I had planned to redo it with the above as it fits much better. I cannot recommend the Kassel brace TBH. Links of my build in my sig.
        • Vincenze
          • Apr 2019
          • 1027
          You can use the above thing with this cross member.
          https://www.r3vlimited.com/board/for...on-bracket-180
