Auto to 5speed Transmission Conversion Write up(56k no
  • morontron
    • Apr 2006
    • 47
    #46
    Not really but you'd better do one hell of a job inspecting them.
    The more old parts you use, the more likely you will have to go back and redo something later when it fails.
    Just use good judgement.
    If I have an airbag car and am being supplied with non-airbag pedals (the opposite problem of what the author of this article had) , what will I need to do to make them fit?
    Also my 1990 BMW 325i has a 3.73 open diff. Will I be able to use this or do I need a different differential? (haha) The parts car is an 87 325is btw.
    Can someone send me the pictures and I will host them myself? jeremyjenewein at gmail dot com
    • Digitalwave
      is a poseur
      • 6302
      #47
      You will have the cut the upper section of the old pedals from the air bag car to use as a steering column support. The steering column is different on air bag cars and the non-air bag pedals won't have the upper support, so you're whole column will just flop around.
      You can use the 3.73 open diff.
      RISING EDGE
      • morontron
        • Apr 2006
        • 47
        #48
        Cool thanks a lot man!
        I'm sure it'll be easier to understand when I have the two pedals sitting next to eachother :)
        • Digitalwave
          is a poseur
          • 6302
          #49
          Yeah man, you will know exactly what I am talking about once you remove the old pedals.
          RISING EDGE
          • ///M42 sport
            • 3952
            #50
            bump for pics
            • Digitalwave
              is a poseur
              • 6302
              #51
              Originally posted by ///M42 sport
              bump for pics
              Have you noticed Marvin hasn't posted in over a year? Give it up man, pics aren't even necessary. I did it using the 10 step/no image write up on bmwe30.net
              RISING EDGE
              • E30FreaK89
                • Apr 2006
                • 437
                #52
                does anybody have the pictures to the article??
                • Digitalwave
                  is a poseur
                  • 6302
                  #53
                  RISING EDGE
                  • FredK
                    • 14764
                    #54
                    I like the writeup on bmwe30.net, the guy sure didn't hestitate to bust out bolt cutters or the sawzall when he got pissed! Seems simple enough.
                    • Digitalwave
                      is a poseur
                      • 6302
                      #55
                      It's a LOT easier than it seems.
                      RISING EDGE
                      • ///M42 sport
                        • 3952
                        #56
                        OK, I'm doing my swap right now complete with pics. Should be done this week. post pics soon.
                        • RL 325i
                          • 129
                          #57
                          Pls post your write up here. I am looking in doing the auto to 5 spd swap for my 90' 325i soon too.
                          Thanks in advance
                          • Digitalwave
                            is a poseur
                            • 6302
                            #58
                            This whole thread is a write up.
                            RISING EDGE
                            • Ender.
                              • Jun 2006
                              • 244
                              #59
                              I cant wait to do this swap, but it won't be until next summer now.
                              Keep on Keepin' on.
                              • Gus
                                • Jan 2004
                                • 285
                                #60
                                am unsure if this has been covered, but the wiring is a little different from mine
                                on two facelifts now, one 325i, one 318i the wiring has been connecting the two green/black wires with the one green/white wire in the reverse light harness.
                                hope that helps, makes it a little clearer
                                JUNGL3
                                1990 "333i" Sport
