Thanks!!!!!!!!!!!!
Auto to 5speed Transmission Conversion Write up(56k no
TwoJ's! thanks soo much!I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_Twin
Originally posted by Marvin View PostHeres the 5 speed conversion progress/write up so far.
Part Lists/Price Guide
5speed conversion kit i purchased from Dave Adams-92 M-technic for $600
1- included in $conversion kit
1- Cross member (Qty 1) Part# 23 71 1 176 574 - $ conversion kit
2- Rubber mounting (Qty2) Part# 23 71 1 175 939
3- Hex nut w/plate (Qty 2) Part# 23 71 1 130 253
5- Wave washer (Qty 2) Part# 07 11 9 932 095
6- Hex nut (Qty 2) Part# 07 11 9 922 856
7- Square headed bolt (Qty 2) Part# 23 71 1 130 250
9- Hex nut w/plate (Qty 2) Part# 23 71 1 130 253
1- Torx bolt (Qty 2) Part# 23 00 1 222 890
2- Torx bolt (Qty 2) Part# 23 00 1 222 893
3- Flat washer (Qty 4) Part# 07 11 9 931 699
4- Dowel (Qty 2) Part# 11 11 1 743 118
5- Torx bolt (Qty 4) Part# 23 00 1 222 887
6- Wave washer (Qty 4) Part# 07 11 9 932 095
7- Hex bolt (Qty 1) Part# 07 11 9 913 015
8- Torx bolt (Qty 2) Part# 23 00 1 222 889
9- Wave washer (Qty 2) Part# 07 11 9 932 112
10- Hex nut (Qty 2) Part# 07 12 9 900 812
1- Pressure plate (Qty 1) Part# 21 21 1 223 026 Cost $56.00 from BMA
2- Clutch disk (Qty 1) Part# 21 21 1 223 671 Cost $74.00 from BMA
3- Clutch rel. fork lever (Qty 1) Part# 21 51 1 204 229 Cost $conversion kit
4- Clutch release bearing (Qty 1) Part# 21 51 1 223 366 Cost $28.50 from BMA
5- Ball pin (Qty 1) Part# 21 51 1 202 659 Cost $.58 from BMA
6- Spring clip (Qty 1) Part# 21 51 1 204 327 Cost $1.30 from BMA
7- Screw fillister head (Qty 6) Part# 07 11 9 919 939
1- Input cylinder clutch (Qty 1) Part# 21 52 1 156 000
2- Hex bolt (Qty 2) Part# 07 11 9 913 477
4- Fit bolt (Qty 1) Part# 21 52 1 151 447
5- Self-locking hex nut (Qty 1) Part# 0712 9 946 400
7- Connector (Qty 1) Part# 21 52 1 151 697
8- Hose (Qty x) Part# 21 52 1 163 714
9- Grommet (Qty 1) Part# 21 52 1 156 082
10- Pipe (Qty 1) Part# 34 32 6 755 555
11- Connector (Qty 2) Part# 34 32 1 151 806
13- Clip (Qty 1) Part# 34 34 1 163 565
14- Output cylinder clutch (Qty 1) Part# 21 52 1 116 300
15- Vent screw (Qty 1) Part# 21 52 1 116 360
16- Protection cap (Qty 1) Part# 21 52 1 154 976
17- Knurled bolt (Qty 2) Part# 21 51 1 203 012
18- Self-locking hex nut (Qty 2) Part# 07 12 9 946 400
1- Supporting bracket (Qty 1) Part# 35 11 1 157 719
2- Gasket (Qty 1) Part# 35 11 1 150 370
3- Self-locking collar nut (Qty 4) Part# 31 33 1 092 887
4- Flat washer (Qty 2) Part# 24 11 1 690 120
5- Hex bolt w/washer (Qty 2) Part# 07 11 9 915 160
6- Stop light switch (Qty 1) Part# 61 31 8 360 420
7- Brake pedal (Qty 1) Part# 35 21 1 154 729
8- Rubber pad (Qty 1) Part# 35 21 1 108 634
9- Bush bearing (Qty 2) Part# 35 21 1 109 541
10- Spacer sleeve (Qty 1) Part# 35 21 1 150 346
11- Tension spring (Qt 1) Part# 35 21 1 152 371
12- Grommet (Qty 2) Part# 35 41 1 113 728
13- Pin (Qty 1) Part# 34 31 1 152 270
14- Clamp (Qty 1) Part# 34 33 1 120 538
15- Clutch pedal (Qty 1) Part# 35 31 1 154 737
16- Rubber pad (Qty 1) Part# 35 21 1 108 634
17- Spacer sleeve (Qty 1) Part# 35 31 1 154 734
18- Grommet (Qty 1) Part# 35 31 1 113 725
19- Tension spring (Qty 1) Part# 35 21 1 102 383
20- Cap (Qty 1) Part# 35 31 1 153 896
21- Stop buffer (Qty 1) Part# 35 31 1 152 237
22- Compression spring (Qty 1) Part# 35 31 1 151 990
23- Fit bolt (Qty 1) Part# 35 31 1 150 407
24- Self locking hex nut (Qty 1) Part# 07 12 9 946 400
27- Bush bearing (Qty 2) Part# 21 52 1 150 345
28- Hex bolt (Qty 1) Part# 07 11 9 912 721
29- Flat washer (Qty 1) Part# 07 11 9 931 020
30- Self-locking hex nut (Qty 1) Part# 07 12 9 964 672
