Transmission Output Flange Socket (30 mm thin wall deep)
    Found a good and cheap socket available in stores for this application. It is a GearWrench 30 mm deep 12 point socket. It does not say it is thin wall, but it is. The part number is 80826. It cost me around $10 at Advance Auto. I believe Sears sells this brand also, so it should not be too difficult to source.
    I did a bit of research, did not find this information previously. My apologies if this is a repost, but figured it would be worth mentioning for anyone else attempting this job.
    I broke 3 other sockets on a very stubborn nut (even w/ applying heat, etc.), so this socket appears to be a quality piece, and much cheaper then the other specialty sockets that are not too readily available (facom, snap-on, etc.).
    Cool .....tkx
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
      Good info.
      Just got a quote of $50 for a non genuine 30mm thin deep wall socket from SirTools.
      Not paying $50 for ONE socket.
        I bought a GM oil sender socket is 1 1/16in ches about 30mm. Works great and bought it at pepboys for about 10 bucks
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
          Just bought this yesterday, part #80826 at Advance.. $11.29. Thanks!
            is this impact rated? I know it is an old thread, but was curious if anyone had hit it with a good impact gun.
              I just bought a Great Neck 6 point socket at Autozone and grinded it down. It only needs thinned out about 1mm in diameter. I've been using it for years. Just another option. Yours sounds better obviously, as it works right out of the box.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
                pretty much did the same. Would have been nice to know there was one that worked out of the box
                http://bmannmotorsports.com/Home.html
                  just ordered one from amazon. going to tackle this job this weekend
                    Thanks to the OP 3 years later still getting the hook up for a part I needed and cheaply!
                      I don't believe it is impact rated but I used this exact socket with a good quality impact this past winter with no issues. Great socket for a job like this.
                        Almost 4 years later and this thread is still helping others out. I actually googled for the size of the output flange and this thread was one of the very first results.
                        Rebuilding since 07/06/2016
                        Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                        Poorboyz Feedback Thread
                          I googled deep thin wall socket and it helped. Thanks
                            thanks for the info
                              hmm interesting. I bought the exact socket mentioned, went to use trial fit and it was too thick.
