For those who want to refresh their factory LSD.
  • Brew
    • 3060
    So I decided to tear my 3.73LSD apart while my car is in the garage for winter.
    I work with a guy who builds Porsche race cars and while I was pulling apart the LSD carrier, he started to recognize some of the parts. It turns out that the LSD unit shares almost all its internal parts with the one Porsche uses, which is made by ZF. And all of those parts are still available.
    Here's all the part numbers:
    "Disc with external splines" is available in different thicknesses to adjust preload. The stock discs in my diff were 2.0 mm thick and I replaced them with 2.1 mm discs and new friction discs.
    I won't be able to test it out for a few months, but I'm expecting at least like-new performance- hopefully slightly more agressive lock-up due to the increased carrier preload.
    '91 318is
  • ///M42 sport
    • 3952
    hmm does that mean you cant get the parts from bmw?
    • xwill112x
      • Jan 2009
      • 4236
      why dont you just weld it?
      • Brew
        • 3060
        Right. You can't buy any internal LSD parts from BMW aside from the bearings and seals.
        Because I want my car to turn.
        '91 318is
        • e30guydownunder
          • Jul 2008
          • 874
          Thanks for the link! Will come in handy, have half a dozen LSD's kicking round :D
          - Chris
          Project M42 - 255 @ 19 psi
          • M-technik-3
            • 18946
            Thanks Brew.
            • erik325i
              • Jan 2005
              • 3567
              Thanks for posting that.
              Erik
              • rwh11385
                lance_entities
                • 18403
                hot
                • shiboujin
                  • Feb 2006
                  • 2791
                  So. what parts should we buy to rebuild a diff? I'm assuming the internal gears are fine. The clutch disks obviously need to be redone. Anything to fuck with ramp angle?
                  • FredK
                    • 14764
                    Great!
                    There's a pretty good writeup on how to replace the parts here:
                    • Brew
                      • 3060
                      You'll need 2 clutch discs, part 951 332 551 00 , and if you want, 2 friction plates, which is number 9( http://www.autoatlanta.com/porsche-p...-91/305-05.php) and available in 3 different sizes to adjust the carrier preload.
                      '91 318is
                      • whiltebeitel
                        • Apr 2007
                        • 2098
                        Look on the 2nd picture in the PDF. Those V-notches are the ramps. They would have to be machined to change the angle.
                        '89 325i track sloot
                        '01 530i daily
                        -Enginerd
                        • shiboujin
                          • Feb 2006
                          • 2791
                          I know. but is there an easy way to change the ramp angle without a machine shop?
                          Bimmer world has the clutches for cheaper.
                          So the thicker dog ear splines increase lockup?
                          • Brew
                            • 3060
                            Bimmerworlds are $75 each, the Porsche ones are $54 each.
                            '91 318is
                            • whiltebeitel
                              • Apr 2007
                              • 2098
                              File? LOL
                              '01 530i daily
                              -Enginerd
