LSD Breakaway Torque Test [pics]
  • Earendil
    • 1662
    I finally dug out the 4.10 LSD I have laying around and did a proper breakaway torque test per the instructions all over the place. What I can't figure out is if my implementation is focked, or if this LSD just has new/hardly used clutches.
    Here is the top down view.
    The input shaft is held in place, and one output on the [picture view] right is held in place. I will then put a torque wrench to the left side and keep upping the torque on my wrench until it slips instead of my torque wrench clicking.
    Another angle.
    So, the torque wrench is going to apply a twisting action to the socket, and the socket to the vice grips. Because the socket is off center towards the wrench, my guess would be that when the wrench experiences 90 ft/lbs, that the center is actually experiencing more (an even longer arm). But perhaps my thinking is off. I am rather tired.
    Help? Isn't 90 ft/lbs high, even for a new low milage LSD?
    And for anyone interested in the components used in that MacGyver scenerio, here they are.
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
    The off center application of torque is going to raise the breakaway point. Knowing the distance from the center of the nut to the center of flange you could calculate the error.
    The factory spec is 65ft-lbs and if you are getting 90ft-lbs you have a very good set of clutches in that differential.
    • Earendil
      • 1662
      So, it turns out that something is wrong with my test. I put the 4.10 in my car and the very first hard corner I took felt weird. Another hard corner, and I was able to feel the back end break loose under application of power. Totally not what the 3.73 LSD felt like.
      I took it home and jacked one of the rear wheels off the ground, leaving the other rear solidly pressed into the ground. I then started the car and slowly let out the clutch, thinking that the LSD should deliver at least some power to the grounded wheel, and cause the car to try and move. Nothing at all, I was able to fully releasing the clutch in first, and have the raised wheel just spin there.
      So, does that mean this diff is no longer an LSD? And if it isn't, how did I go so wrong with my test? Any ideas?
        With the diff in the car, jack up the left rear corner and use a torque wrench on the axle nut. Apply the torque clockwise.
        • Earendil
          • 1662
          And with a similar principle as when it's out of the car, have the input shaft "locked" in place be engaging first gear?
          I'll give this a shot.
            The transmission must be in neutral. And obviously the parking brake must be off.
            I just noticed that you had the diff input shaft restrained when you tested the diff out of the car and that is wrong.
            • LJ851
              • 7919
              Yes, that is wrong. You only want the the 2 outputs involved.
              EDIT: What is the diff out of? Is it possible it is a non-clutch type LSD say from an ix?
              Lorin
              The M30 is God's engine.
              • Earendil
                • 1662
                Seriously? Damn. I was taking my advice from this other thread I started, where they state that the input shaft must also be locked in place.
                The guy seemed to know what he was talking about. See post #5.
                No, it's not out of an IX. The guy is a rather prominent forum member here (8000+ posts) so I sorta trusted him. Perhaps he delivered the wrong diff to me. In any case, that'll teach me to trust sellers!
                The guy that sold it to me said he pulled it himself out of the car, tested it, and was going to put it in one of his own cars before plans changed. He had been sitting on it for a year before deciding to sell it.
                I'll try the torque test in the car. But I know for a fact that when it was out of the car, I was able to spin each output flange independently with my hands :roll:
                Thanks guys. I'll let you know how it goes.
                • LJ851
                  • 7919
                  Originally posted by Earendil
                  I'll try the torque test in the car. But I know for the fact that when it was out of the car, I was able to spin each output flange independently with my hands :roll:
                  Hmmmm.. That doesn't sound good. What does the tag on the diff say?
                  Lorin
                  • Earendil
                    • 1662
                    Tag says 4.10S. Also, it spins like an LSD (same direction). It's just easy to overcome the rather notchy resistance I feel with it. My 3.73S when I took it out of the car seemed rock solid between each output shaft.
                    I'm thinking this diff is seriously toast...
                    • LJ851
                      • 7919
                      Does it sound funny when you turn really tight, like full lock circles?
                      Lorin
                      • Earendil
                        • 1662
                        Not at all. And with the interior torn out (I can look back from the drivers seat and see my spare tire) I would notice a difference. The only thing I notice while driving is what feels like one tire breaking loose.
                        Okay, well there is a clunk when I go into reverse suddenly too. I'm hoping that is just one side of the diff not being completely tight ;)
                        Checking that tonight when I get off work.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          If you can turn them opposite by hand, it needs a rebuild.
                          To test, you need the input open like jlevie said or you are just meshing the gears themselves and not testing the limited slip.
                          john@m20guru.com
                          Links:
                          • digger
                            • Nov 2005
                            • 6095
                            how much breakaway is too much for a street driven vehicle?
                            Got a spare 188 diff here with 3 clutches and standard 2mm dog ear plates (i.e. the thick shim was replaced with clutch and dog ear plate of same combined thickness) that seems to be 105 ftlb which seems excessive
                            the old unit when stock was 40 ftlb so seems like too much of an increase given changes made or maybe because the clutches are fresh ?
                            EDIT: with only 2 new clutches and the 4mm shim it was 70ft-lb breakway i.e. this is 100% stock setup
                            • TobyB
                              • 5243
                              Sounds good to me! Let me pm you my shipping address!
                              heh
                              I've noticed that when spanky- fresh, you get nice numbers like what
                              you're seeing for 2 plates, but after a track day
                              and an oil change, it drops by at least 25%.
                              I've never tried the 3- clutch setup, but
                              those numbers seem like the very high end of 'yeah, that'll wear smooth pretty quickly'-
                              me, I'd try it. But then, anything short of a spool and I'm in.
                              t
                              curious, too.
