What diff do I have?
  • Mark 42
    • Apr 2012
    • 291
    I got the number on the tag on my Diff - it's 4 10 9661
    Is that enough to determine whether it is LSD?
    I gather it's a 4.10 ratio ring/pinion.
    It seems to spin both tires most of the time AFAICT
    But it's a 1991 318i (4 door, M42) so I would have thought it has an open diff.
    Is there a way to know for sure?
  • Pl3wA
    • 1589
    i heard that if you travel at 80 and you are at 3,500 revs you have a 3.9 or something. im not exactly sure.
    if you lift the back of the car and turn a wheel by hand and they both spin the same direction, you have a diff. if they spin in different directions, you dont
    • Cronopoulos
      • Jul 2011
      • 2187
      Jack the rear-end up, spin a tire....
      OR
      R3V method - do a burnout, hurrrrrrr
      Project log -- DIRTY 30
      2.7i * Megasquirt tuned * E85 powered
      • pandaboo911
        • 2070
        the tag will have an S stamped in front of the ratio, so you have a 4.10 open.
        the bottom of the case will also have a big S printed on it.
        • Jand3rson
          • 37587
          This is how you tell. Much easier than the rest of the responses.
          • CHIF8008
            • 3447
            "S" stamped on it.
            or jack it up and spin the wheels
            -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
            -The Beauty in the Tragedy-
            MECHANIC SMASH!!- (you all know you do it)
            Got Drop?? ;-)
            But of course
            E30s are know to be notoriously really really really ridiculously good looking
            • george graves
              • 19996
              See the opposite end of the arrow? See the metal tag on it? That's what you're looking for - for an "S"
              Originally posted by Matt-B
              • Robotin
                • Jun 2011
                • 4471
                ggoing 80MPH, at 3,500 revs.. in which gear?
                and i think if i jacked my car up, i would realize if i had a diff or not without spinning the tires..
                1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                1989 325ix [zinnoberrot] $OLD
                1970 2002 [Nevada]
                Originally posted by Herr Faust Schinken
                guy must have slid into something that doesn't look like a car vs car hit
                Originally posted by ak-
                Must of slid into Rob
                • peytonracer4
                  • May 2011
                  • 524
                  :rofl: i'm pretty sure he has a diff regardless. i think you meant to say LSD.
                  this is correct. if you spin one wheel and the other goes the opposite direction you have an open diff. both wheels must be raised obviously
                  • Pl3wA
                    • 1589
                    im so high right now. but seriously, dont bother checking. you will be disappointed
                    • themoonman
                      • Aug 2011
                      • 196
                      what does it mean if you spin one wheel and the other wheel does not spin at all?
                      • Mark 42
                        • Apr 2012
                        • 291
                        $1289.50
                        • Pl3wA
                          • 1589
                          Originally posted by Mark 42
                          $1289.50
                          thats about exactly the amount, yes
                          • TobyB
                            • 5243
                            you left it in neutral...
                            t
                            • Mark 42
                              • Apr 2012
                              • 291
                              Originally posted by TobyB
                              You left it in neutral...
                              Good point.:bow:
                              Or the parking brake is dragging?
