Shifter too far forward?
  • MattPro
    • Dec 2010
    • 502
    With my shift boot installed I can't shift into reverse, it hits the shift boot frame far before the engagement point. All other gears seem to be okay, and I can get into it with no shift boot installed.
    Are my motor mounts trashed? Every thread I've been reading has people shredding shift boot, but I can't even get into gear. Is this a mount issue or something different?
    M20B25/G260/z4m shifter
    Thanks.
    Thanks,
    Matt
    Check out my BMW Fault Code Index
    '89 Turbo M20 Zinno Cabrio (scrapped)
    '89 Zinno IX (sold)
    '91 Granit Turbo S52 Sedan (scrapped)
    '91 WIP (scrapped)
    '13 F10 Carbon Black 550iX MSport
    '91 iX Sedan
  • e30trooper
    • 11576
    Thanks.
    check motor/trans mounts and the carrier for the shifter
    • MattPro
      • Dec 2010
      • 502
      Carrier is good, so does that only leave mounts?
      I don't see anything wrong with the mounts so I want to be 100% before I just go replacing them.
      Thanks,
      Matt
      '89 Zinno IX (sold)
      '91 WIP (scrapped)
      '91 iX Sedan
        Might you have installed the shift lever 180 out?
        • MattPro
          • Dec 2010
          • 502
          It's a straight lever, so sadly that's not it.
          Is there a way to check motor/trans mounts? Visually they look fine, no cracks or anything.
          Thanks,
          Matt
          '89 Zinno IX (sold)
          '91 WIP (scrapped)
          '91 iX Sedan
          • Jean
            • 18228
            Are ALL your shifter parts fresh?
            • AndrewBird
              The Mad Scientist
              • 11898
              What about shift bushings? If they are worn and sloppy, it can cause this.
              • MattPro
                • Dec 2010
                • 502
                They should all be brand new according to the person I bought the swap from, everything feels tight and there's little play so I believe that much.
                Thanks,
                Matt
                '89 Zinno IX (sold)
                '91 WIP (scrapped)
                '91 iX Sedan
                • reelizmpro
                  • 9559
                  Should have bent the lever for e30 use. Throw should be very short with that lever though. Check the front carrier mount bushings.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    I would agree with this as well, exactly what I did the first time without thinking about it.
                    Project log -- DIRTY 30
                    2.7i * Megasquirt tuned * E85 powered
                      Swap? What parts were swapped?
                      • MattPro
                        • Dec 2010
                        • 502
                        Did not know that, any details on the bend? If that's normal for that shift rod to be bent then that's most likely all of my problems right there.
                        Oh, probably should have clarified that... The transmission was swapped in, it used to be an auto.
                        Thanks,
                        Matt
                        '89 Zinno IX (sold)
                        '91 WIP (scrapped)
                        '91 iX Sedan
                        • e30leigh
                          • Mar 2012
                          • 481
                          e30 shifters are not straight. they have a slight angle backwards. so do the shifters from z3's that we use to get a nice short shifter.
                          id say you have the wrong shifter in
                          • MattPro
                            • Dec 2010
                            • 502
                            I was wrong about what shifter I have, apparently it isn't the z4m just the z4... it's the shortest z4 shifter in this thread (z4 2.5).
                            According to that thread it doesn't need to be bent but that could be wrong.
                            EDIT: Forgot link...
                            Thanks,
                            Matt
                            '89 Zinno IX (sold)
                            '91 WIP (scrapped)
                            '91 iX Sedan
                            • e30leigh
                              • Mar 2012
                              • 481
                              id say it does need to be bent. other wise you run out of of room.
                              the only other thing that could be giving you an issue is the the shifter mount off the back of the trans to the body where the shifter lever mounts to it under the hole in the floor.
                              if the car was converter and that part isnt an e30 one, and its too short. then that will place your shifter too far forward and create issues with getting into gears.
