Is it good to change manual transmission fluid?
  • RawToast
    • Nov 2011
    • 324
    So I've bought Royal Purple Synchromax transmission fluid but I just heard from two friend's of mine that it is not beneficial to change manual transmission fluid in E30's. No idea why but they said something about the age of the car / oil.. Not quite sure. Opinions?
    As a side note, what oil should I use for my differential?
  • RoadWarrior
    • Jan 2011
    • 77
    I just changed mine while my swap was out. I used Redline MTL 90. Its night and day. Smoother gear changes all around the transmission feels better. Change it and call it a day.
    -seth
    • UserError
      • 86
      BMW service requirements state that you should change your transmission and diff oil every 30k miles or so, as part of an inspection 2 service. As for diff oil, your best bet would be 80W90 GL-5 for regular differentials, and 85W140 GL-5 with LSD additive, if you've got a limited slip unit.
      • reelizmpro
        • 9523
        Oh yeah, nothing beats used vintage gear oil. The older the better.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Quadrajet
          • Jul 2008
          • 1278
          Lol!
          • TobyB
            • 5242
            MTL every 30k. Give Plebian Purple to friends for entertainment.
            t
            • reelizmpro
              • 9523
              t
              I go extended on synthetic gear oil ...50-60k. It comes out almost as good as it went in. Won't hurt to change it at the factory spec though.
              88 M3 - LACHSSILBER
                • 37829
                Definitely a good idea to change trans/diff fluids.
                I use generic Valvoline or Castrol 75w90. No synthetic and nothing fancy.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • ieatpeople
                  • Mar 2008
                  • 883
                  OP, your "friends" are sort of right, just not about a manual trans.
                  i've always heard that if you have a high mileage automatic trans that you should not change the fluid, just the filter. i don't agree with that, but alot of people do.
                  for a manual trans, changing the fluid is good for it. and it makes it nicer to drive.
                  Originally posted by BillBrasky
                  That's like Vlad challenging Chip Foose to a car painting contest.
                  Originally posted by acolella76
                  i'm pretty sure 'Phillis' is short for syphilis
                  2007 CVPI, stock and slow
                  1994 tercel, 5efhe swap, i/h/e
                  1984 t-type, 5.3/th350 swap in progress
                  My newest addition:
                  Rebecca Arlene, born 4/19/2013
                  • entrepreneuR
                    • 206
                    Since we're are the topic...how many quarts do i need for a complete trans flush? (5 spd)
                    • Holland
                      • Nov 2008
                      • 7178
                      It's bad to FLUSH high mileage auto transmissions after not being serviced ever. Drain and fills are ok.
                      Originally posted by DEV0 E30
                        • 37829
                        2 for the trans, 2 for the diff. You'll have extra.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • entrepreneuR
                          • 206
                          Gotcha..thanks!
                          • drumad
                            • Aug 2009
                            • 1700
                            Didn't see it mentioned yet but check what sticker your tranny has. It may take ATF also.
                            2008 335i - n54b30
                            1991 318i - m52b28
                            1994 fzj80 - LAND CRUSHER
                              • 37829
                              That's true. Some Etas and M42 cars take ATF in the trans.
                              Grover Beach, CA
                              www.BimmerHeads.com
