Is it good to change manual transmission fluid?
  • RawToast
    • Nov 2011
    • 324
    Originally posted by drumad
    Didn't see it mentioned yet but check what sticker your tranny has. It may take ATF also.
    I've got a 325i but my tranny fluid cap says ATF only... Kind of confused... Not quite sure if the previous owner may have replaced it or that's what it really uses.
    • RawToast
      • Nov 2011
      • 324
      Anyone??
      • reelizmpro
        • 9557
        Then use ATF only. Some manuals use ATF, it's no mistake. Some people like Redline ATF4+ synthetic.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
          • 37833
          Or just take a look at the fluid that comes out. It's very easy to tell the difference between ATF and gear oil. Color, thickness, and smell are completely different.
          Grover Beach, California
          BimmerHeads.com
          • stamar
            • Apr 2011
            • 1362
            you aree looking at the "CAP" on your power steering system. it says atf only.
            Ok no offense. Lets take this slower. You are not ready to change your manual transmission oil yourself.
            Get a paper repair manual, bentley or haynes. Start to read about the process again and again. It needs a tool thats not always easy to find. Read it beginning to end, 10 times. Leave it in the bathroom.
            your manual transmission is changed by a 17 mm allen key. Do you have one of those?
            theres a tag undeneath the trannny by the drain plug actually. If its red it takes atf. If its green it takes full synthetic mt 90. ( mobil 1 actually is what it orignally said) if it has no tag it takes regular 70-80 wt gl4 or synthetic redline mtl, or rp synchromesh.
            • drumad
              • Aug 2009
              • 1700
              Gear oil makes me gag.
              2008 335i - n54b30
              1991 318i - m52b28
              1994 fzj80 - LAND CRUSHER
              • ButtJuice
                • Dec 2009
                • 2609
                Anyone know what oil the SuperEtas 5 speed transmission takes?
                1991 318is - Sold
                1986 325 - Sold
                Instagram - Lamoursum
                • bmwman91
                  • Oct 2004
                  • 3134
                  There's a sticker on the Getrag 240 (5 spd manual) that says ATF only. Despite that, me and every M42 guy I know has been putting RedLine MTL in for at least a decade with no problems. It shifts a hell of a lot smoother that way.
                  Transaction Feedback: LINK
                  • stamar
                    • Apr 2011
                    • 1362
                    If you have a red tag use mtl. or better yet use dexron vi its semi synthetic for 4$ a quart at walmart. Best stuff in the world.
                      • 37833
                      Look for a tag as stated in this thread. If no tag, gear oil.
                      BimmerHeads.com
