Another Auto to 5 Speed Thread (Parts List)
  • McGyver
    • 4634
    I am trying to put together a parts list for my 1991 auto to 5-speed swap. I’ve pulled a few trannies to replace clutches and reseal them, but never a conversion like this. I’m hoping someone can verify that I have thought of everything. Parts with a “*” next to them are ones that I can see buying from the junkyard to keep costs down, but input on what can be bought used would be helpful too.
    Conversion
    -Master/Slave Cylinder*
    -Reservoir to Master Hose*
    -Master to Slave Hose*
    -Manual Flywheel*
    -Manual Driveshaft*
    -Flywheel Bolts x 8
    -Transmission*/Support*/Mounts*
    -Pedal Box*
    Shifter
    -Carrier Arm*
    -Selector Rod*
    -Bitch Clip*
    -Z3 Lever
    -White Plastic Cup/O-rings/Spacers/Rubber Seal/Boot*/Knob*
    Seals
    -Shift Shaft
    -Output Shaft (engine/tranny)
    -Input Shaft (tranny)
    Clutch
    -Clutch
    -Pressure Plate*
    -Throw-Out Bearing
    -Pilot Bearing
    -Throw-Out Arm
    -Pivot Pin
    -Retaining Spring*
    -Clutch Bolt x 6
    -Pressure Plate Bolt* x 6
  • mikewbd
    • May 2012
    • 39
    Why reuse pressure plate bolts, new fasteners can't be that expensive.
      • 34839
      because McGyver...
      also, i wouldn't reuse things like springs, clutch forks, pivot pins, etc. these parts are cheap and make sense to replace. You don't want to pull it apart later over a $5 part that you re-used.
      I'd also strongly suggest replacing the selector rod joint. I wouldn't use old mounts either, but at least those are easy to replace later if they fail.
      • Wanganstyle
        • 2828
        I'd strongly suggest buying a NEW stainless hose from master to slave; as the original e30 items are rubber and do degrade over time if you are planning on junkyarding one. One can buy a longer stainless hose to avoid using a flex + hard line if desired.
        the fluid feed line is also rubber and could use a brand new OEM part.
        • McGyver
          • 4634
          well the pressure plate bolts will only be $3, so I might as well get new ones. I just remember reusing them when I was working at the shop over the summer. The spring is also about $3 so getting a new one would probably make sense too. I was just being penny smart and pound foolish about them.
          When it comes to pulling a junkyard tranny, is there anything can look for to pick one transmission over another? All I can think of is to look for a low milage one based on the cluster (which doesnt really mean anything) and to drain the fluid to see how clean it looks. I guess looking for one that doesnt appear to have past seal leaks would also be a good idea.
          • Wanganstyle
            • 2828
            changing seals is highly suggested on any G260; they are um.....at LEAST 20+ years old :)
            • jeffnhiscars
              • Jun 2011
              • 6011
              I would suggest not using used mounts, hydraulics or pressure plate
              Alice the Time Capsule
