m42 flywheel swap
  • Bimmer805
    • May 2012
    • 207
    m42 flywheel swap
    i recently bought a m20 flywheel and pressure plate/clutch from a member here about 5 months ago for my 318is and i finally gathered all my necessary parts for the swap. well i took it to a friend to do the swap for me. and he ended up telling me that the clutch and pressure plate are squeezed together and he said it doesnt seem right to him. he looked at the flywheel and told me that the flywheel doesnt have an indentation on where the clutch will sit on? my question is are all M20 single mass flywheels are the same? or is there a specific m20 flywheel that will fit for my M42?
    Luis
    Instagram: Bear_e30
  • Dj Buttchug
    • Jun 2010
    • 7672
    pretty sure any single mass m20 fly will work. What indentation? The pressure plate either bolts up or it doesnt...
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Bimmer805
      • May 2012
      • 207
      he said it bolts on but also said the flywheel needs an indentation so the pressure plate and flywheel sits flush. he said when he put it on that there squeezed together soo much that it will always be in gear.
      Luis
      Instagram: Bear_e30
      • Bimmer805
        • May 2012
        • 207
        heres what it looks like. now its been shaved and balance
        Luis
        Instagram: Bear_e30
        • bmwman91
          • Oct 2004
          • 3134
          Make sure you put that spacer ring BEHIND the flywheel, against the crank.
          Transaction Feedback: LINK
          • Bimmer805
            • May 2012
            • 207
            yea the spacer is between flywheel and crank. and also he told me that the clutch should spin freely when the pressureplate is bolted to the flywheel. is this true?
            Luis
            Instagram: Bear_e30
            • Balleristic31
              • Aug 2009
              • 4198
              Incorrect. It's the opposite. Once the pressure plate is bolted down the clutch is locked in place.
              -NICK
              • e30leigh
                • Mar 2012
                • 481
                LOL and im sure that ring goes ontop of the flywheel under the head of the bolts..... infact im positive it does. why would you space the flywheel off the crank.... thats a terrible idea asking for disaster
                • Dj Buttchug
                  • Jun 2010
                  • 7672
                  its a m20 fly swap you gay boi phaggot.
                  It requires that amount of space to clear the upper pan so you are in fact WRONG. Dont clutter threads up when you know nothing about the subject.
                  k thnks
                  love buttchug
                  Ig:ryno_pzk
                  • bmwman91
                    • Oct 2004
                    • 3134
                    Aaaand the buttchug lays down the law...
                    • Bimmer805
                      • May 2012
                      • 207
                      alright thanks bro
                      Luis
                      Instagram: Bear_e30
                      • Bimmer805
                        • May 2012
                        • 207
                        It requires that amount of space to clear the upper pan so you are in fact wrong. Dont clutter threads up when you know nothing about the subject.
                        K thnks
                        love buttchug
                        rotfl!!!!
                        Luis
                        Instagram: Bear_e30
                        • Bimmer805
                          • May 2012
                          • 207
                          i never asked about the spacer
                          Luis
                          Instagram: Bear_e30
                          • Bimmer805
                            • May 2012
                            • 207
                            so all of it together should look like this?
                            and what side of the clutch goes up or down because one side of the clutch sticks out?
                            Luis
                            Instagram: Bear_e30
                            • Bimmer805
                              • May 2012
                              • 207
                              bump
                              Luis
                              Instagram: Bear_e30
