auto reving to 60km/h in first
  • -REINBOTT-
    • Aug 2004
    • 31
    hey
    got a 1990 318i auto and lately its been sluggish in changing gears.
    it sometimes revs to either 50 or 60km/h in first
    just wondering if anyone knows whats going on .. and what to do about it
  • 92 mtechnic cabrio
    • 4907
    e30 trannies don't shift at a certain speed, it shifts when certain criteria is met, like, how open the valve body is when compared to how far your foot is down on the gas pedal.
    If anything, there may be something wrong with your valve body, or you may need to adjust the tension on the cable between the throttle body and the automatic transmission.
    R.I.P 07/01/09 - 04/23/10 :(
    • Digitalwave
      is a poseur
      • 6299
      First order of duty for any automatic is always to change the fluid and the filter on the tranny, then take it from there.
      RISING EDGE
      • -REINBOTT-
        • Aug 2004
        • 31
        thanks for that guys
        ah quick question where is the filter for the tranny
        • AdamF 88iS
          • 2051
          Filter is on the bottom of the valve body, you have to take the pan off.
          You may also have a throttle valve cable problem.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • Axxe
            • Aug 2004
            • 3355
            Best solution for an auto is a 5-spd.
            Keep it slideways!!
            • -REINBOTT-
              • Aug 2004
              • 31
              yeh mate .. am thinkin of going manual
              wouldnt mind doing an engine change down the track .. M50 hopefully
              does anyone suggest a specific manual transmission taht will work with the m42 atm but maybe later with the m50?
                • 34844
                doesn't exist. I would try to get your auto working for now until you can do an M50 swap later.. M42 auto? eeww... :P
                • -REINBOTT-
                  • Aug 2004
                  • 31
                  yeh sorry its not m42 i was reading up at it at the time and obviously put it down
                  ah k thanks for that
                  • -REINBOTT-
                    • Aug 2004
                    • 31
                    hey guys
                    got the car serviced the other day
                    got a new tranny filter and oil and also put some oil in that revitalises the seals
                    however it doesnt seem to have worked .. im guessing that means ill need a new gearbox if i want the problem to stop
                    mechanic said the rod in the auto was loose aswell that explains why the car wouldnt start sometimes
                    was talking to my mechanic and he said that its not worth going to a manual just stay with the auto .. i can get a recon auto for $1600 (aussie dollars) so might have to look at that
                    do you guys thinks its farked or any other options i can possibly look at
                    • mbonanni
                      • Sep 2011
                      • 6236
                      Sounds like for that you can get all the five speed parts and labor. Idk how much Aussie dollars are though compared to us..
                      • whodwho
                        • Jun 2008
                        • 1547
                        wow you must of dug deep to pull up a 05 thread...
                        My M20 Frankenbuild(s)
                        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
