IX rear diff
  • Zreberlcoe
    • 1555
    IX rear diff
    Will a 1991 IX rear diff fit in a 1991 325i? Im looking to get an LSD and there's one out of a 1991 325ix but I'm not sure it's the same.
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • nomansland92
    • 1657
    The ix diffs have a vc in them, I believe they lock at 90% unlike the rwd ones. iirc it will still bolt up and work fine.
    IX being restored here
    Ix turbo build here
    • Zreberlcoe
      • 1555
      So what does that mean, 90% locking?
      BMW
      • nomansland92
        • 1657
        Pretty much just means that one wheel will spin 10% of a rotation before it looks in. Most LSD diffs are around 40-50% So it will go better in the snow but it can make you car a little more tail happy.
        Ix turbo build here
        • Zreberlcoe
          • 1555
          Better for drifting😏
          BMW
          • Zreberlcoe
            • 1555
            So I bought the diff and subframe since it only has 53k on it.
            Now from what I can tell the sucker can bolt right up so that's good. I'm going to put poly bushings in it from Ireland engineering as well:) But here's my question, in the future, when I can afford it, I'm going to put in Ground Control Coilovers so should I put in camber adjustments now or then?
            BMW
            • Ether-D
              • Sep 2011
              • 2838
              Do the camber corrects now if it's feasible, just to save some work.
              I have a ix 4.10 rear diff in my cabby and its not really that tail happy (I believe it has some wear on it though).
              Originally posted by Andy.B
              I was born on 3/25…
              • Zreberlcoe
                • 1555
                Will I be cambered too much on stock ride height and risk killing tires?
                BMW
                  • 34839
                  the VC won't survive long for drifting.. you'd be better off with a clutch type LSD built for that purpose.
                  if it's just a DD or used for autox/HPDEs it'll be fine though.
                  • Zreberlcoe
                    • 1555
                    It was a joke. I'm going to track and auto-x this car, no drift. The body is too clean.
                    BMW
                      • 34839
                      heh, ninja quote.. see my updated post :p
                      when it works it works well. at 51k miles it should be like new. Mine isn't totally dead but I can tell it's not 100% anymore (~260k).. it just doesn't rotate like it should anymore, and I can feel the loss of traction in the rear especially on the inside corner. but that's after years of hard use!
                      • Zreberlcoe
                        • 1555
                        Ninja is right. I also bought it because snow is coming here in colorado and it is my DD so I want to prepare the car for snow usage as well as I can.
                        BMW
                        • Wanganstyle
                          • 2828
                          if your car already has an original LSD unit it will be a clutch type unit and honestly better for all purposes than the Viscous unit.
                          the viscous unit is really weak compared to the bmw clutch type unit; the Xi model e30's don't need as aggressive a rear LSD as they have..... all wheel drive!
                          viscous LSD units are common in lower Subaru AWD models as well; STi models have Gear type rear LSD or Clutch type for ultimate performance.
                          • Zreberlcoe
                            • 1555
                            I have a 325i so anything is better than the one tire fire.
                            BMW
                            • Wanganstyle
                              • 2828
                              plenty of 325i's and 325e's have LSD units equipped OEM.
                              plenty of 325is's have OPEN diffs from BMW - the one I race did.
                              before you take the car apart check for LSD?
