no clutch shifts?
  • Jparkr
    HR Admin
    • Jan 2006
    • 3494
    no clutch shifts?
    ok i have a friend who does it constantly after he gets going. i can do it to in the E30 but i wanna know if its bad for anything that im not thinking of. (he also has a 2005 focus so things may be diffrent)
    He swears it isnt and is accually better because you dont have to engadge the clutch all the time which keeps it lasting longer (makes sence)
    anyway if your onclears what im talking about its when you let off the gas at a certain RPM (my iS its about 3,500) and then you can smoothly slide out of one gear and into the next. it doesnt grind or anything but it just doesnt feel right at the same time.
    oh yea this if obviously only in standerd slow/normal speed street driving nothing performace about it.
    anyone have any opinions on this? or accually know if it is bad or good. im currently not doing it just in case.
    1987 PRO-3 car /1990 325is (2.7i Concours)
  • E30 Wagen
    Uh, i wouldn't do it. It can't be good for it... Clutches are used for a reason, and can last a long time.
    • Digitalwave
      is a poseur
      • 6299
      I'd certainly rather my tranny last longer and my clutch last shorter than vice versa.
      RISING EDGE
      • 808BMW
        • 2910
        It's harmless if you can do it well.
        If you suck and just keep grinding the gears, then obviously your fucking up.
        The clutch in my dads truck sucks and I do it all the time, I used to do it alot in my car, but now its mostly when people don't believe you don't need the clutch and I have to show them.
        P.S. the master cylinder in my dads truck broke once while in town. Turning it off, then putting it in gear, starting the truck and driving home with no clutch is a lot better than coughing up $100 for a tow home :P
        • Joe318is
          • Sep 2005
          • 6451
          808 is right [wtf kinda name is that?]
          As long as you dont grind em youll be fine! I can do it in my e30, but ive ruined on tranny so far, not as a result of not using the clutch. I had an old 8v GTI that only needed the clutch when getting into first, downshifting wad no issue either!
          Originally posted by vlad
          • BENdashdash
            Tom is not my friend
            • Aug 2004
            • 2506
            Just about any car can do it, in a window of about 100 rpm's for each gear. I used to do it often until I heard its bad for the syncros
            • wastedincome
              • Aug 2004
              • 906
              I know many people who shift clutchless w/ there motorcycle's, my self included. BUT I wouldn't do it to my car
              Wastedincome420@yahoo.com
              CURRENT STOCK LIST:
              00' e38 750iL HighLine=Highway Queen
              92' e30 318 vert=Aint going anywhere
              91' e34 535iM=Aint going anywhere
              91' e34 525iA=For parts
              92' e34 535iA=For parts
              • mikeedler
                • 6707
                I used to do it alot, till i broke a couple of shift levers!!! its lots a fun at 6300rpm, and slamming into the next. the best is, i used to never let off the gas pedal either.
                i know its a bit different than what your talking about. I think its a terrible idea. my brother when i was younger used to downshift into 2nd with his automatic ford--to save on brakes, till the trans fell apart, and it cost him 2000 dollars to replace the trans, vs. 50 dollars for some brake pads.
                • 325Projectz
                  • Jan 2005
                  • 1956
                  :rofl:
                  91 m3
                  • 808BMW
                    • 2910
                    808=Hawaii Area code
                    BMW= some lame car I dont even drive
                    That would be powershifting.
                    And downshifting in an automatic is bad, it's not designed to take that kind of stress. IMO it's alright with a 5 speed. Theres a lot of hills around here and its killer on your brakes if you drive an auto.
                    • mikeedler
                      • 6707
                      no shit?
                        • 34839
                        I downshift my automatic all the time.. mostly to pass though, never to slow down. die bitch die!
                        • equate975
                          • Jun 2004
                          • 3382
                          I take mine out of gear frequently without the clutch, I can "match" the rpms so the shifter comes out very smoothy as if I was using the clutch.
                          Rollin' with a Geistkuchen
                          • Victell
                            • 1083
                            Truckers only use the clutch for takeoff from a dead stop.
                            • ehlpitel
                              • Dec 2004
                              • 118
                              I don't know about putting it in gear without the clutch but I always take it out without pressing the clutch.
