Are all E30 driveshafts the same?
  • ClayW
    • Apr 2011
    • 377
    Are all E30 driveshafts the same? M10, M20, M42....S14? Same front and rear flanges?
    Yes or no, what are the lengths?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • kronus
    • Apr 2008
    • 13032
    no
    6 cyl:
    auto and manual are different lengths
    '87 manual etas came with big-guibo front sections
    don't know about 4 cyl
    cars beep boop
    • reelizmpro
      • 9552
      No, Auto shafts are different from Manual. Of the manual shafts, there are large (late ETA, M3) flange/guibo's and small. There's also early and late center support bearing. The shaft separates and trans flanges can be removed so it's a matter of matching everything up and keeping it balanced. For instance, my vert had a small flange driveshaft so I got a large flange from someone on R3v and got the matching front half (someone took the rear half) of the driveshaft at the yard. I had both parts rebuilt and balanced.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • blunttech
        • 12850
        What do you need clay??
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • ClayW
          • Apr 2011
          • 377
          I'm trying to determine the compatibility of an E21 5 speed with an E30 driveshaft to be installed in a 2002. Simple, right?
          • Eric
            • 5142
            Sounds fun!
            • Sea Aych
              • Apr 2013
              • 765
              M42/M40 have different drivehsafts than their M20 counterparts (auto and 5speed) too
              1988 Atlantisblau Euro/Japanese 325i Cabriolet
              1989 Schwartz 325i - now M50 powered! - now very dead
              1998 Toyota 4Runner Limited
              My 17,000km Big NA National Parks trip!
              • Norbert
                • Sep 2013
                • 64
                Hello Guys!
                Denmark here!
                I have m20b20 320i 6 cylinder from earlier model (without a rear light facelift).
                I have finished my original differential (as it i am quite sure was never changed in the lifetime...
                I took Differential from newer model e30 (with a rear light facelift) of my friends who has same 320i model just never. His diff is bigger (the axle exits sit slightly further to the back of the car). I tried to mount it on my drive-shaft which connects well, but it does not allign with the mountings on the top (4 big screws) where the holding bracket is.
                I roughly measured the lengh of the drive shaft from the rubber piece near the gearbox untill the place where it goes with the connection of the Diff. It came to be 150cm's 1.5meter (59.0551 inches). I realise my original one is bit too long for the differential i am trying to fit (connection part which connects with the Drive shaft extends more from the differential case, than on one i had before.)
                Question:
                Does anyone know exactly which year frame i have to go for or which configuration model i have to choose to be lucky to choose the right drive shaft so that it fits the diff and diff fits the mounts?
                Hope i was clear enough and if not please ask as i am not native American-English speaker and might have boggled something up:)
                Kind regards,
                Norbert
