Transmission sitting for 14 years- good?
  • lolcantturn
    • 4588
    Hey guys,
    Found a G240 trans for my car nearby low miles. But it has been sitting in inventory for 14 years. I reckon with a fluid flush and new seals it would be good. What do you guys think?
    Originally posted by TSI
    OEM+
  • rcsoundn1
    • Nov 2012
    • 3361
    Wow, but I would give it a good flush, and let it heat up before going for a drive.
    • rturbo 930
      • Dec 2005
      • 2629
      I'd buy it. I can't imagine why there would be anything wrong with it.
      • lolcantturn
        • 4588
        Figured there wouldn't be a problem if it was sitting.
        OEM+
        • packratbimmer
          • Dec 2009
          • 1335
          Make sure the nub that goes into the pilot bearing is not rusted from sitting that long. Same for the rear flange mating area where it meets the seal. Sounds like you are planning new seals anyway - good idea. You probably know this, but make sure to seal the flange splines with Kuril or something comparable when changing the seal.
          • TobyB
            • 5298
            If it had GL5 in it, sitting might hurt it.
            otherwise, it's fine.
            t
