2nd gear downshift lockout/grind only at high RPM's
  • Th3importedguy
    • Mar 2014
    • 190
    2nd goes in perfect when up shifting or when downshifting and lower RPM's. Under 4k it will go in just fine but anything over than it grinds pretty loud so and it seems to lock me out of that gear. i never force it when it grinds so im not sure if it actually locks me out. What could this be?
    E30 is life :finger:
  • Dirty325ix
    • Sep 2012
    • 689
    Same problem over here...had it happen on both transmissions I have owned so I chalked it up as driver error
    but sub'd for the real answer
    • papag1234
      • Feb 2012
      • 297
      Sounds like worn synchros
      • TobyB
        • 5293
        ...or a failing pressure plate...
        Does it do it if you match revs first?
        t
        • MPLFoster
          • May 2013
          • 1490
          t
          this.
          my pressure plate is fucked right now so im forced to rev match going down.
          form.follows.function IG @mplfoster
          • 5Toes
            • 9836
            you should rev match going down anyways, the synchros are worn out and its hard for them to make up the difference
            • AndrewBird
              The Mad Scientist
              • 11898
              Why are you down shifting above 4k rpms? Try slowing down a bit first.
              • MPLFoster
                • May 2013
                • 1490
                my synchros are very worn as well. had to rush my 5-speed swap and used a high-mileage G260. so with the worn synchros and less than perfect pressure plate i was already accustomed to rev matching. Now it's so bad that sometimes i'll have to pad the throttle a bit going up a gear if the revs aren't in the right spot.
                • Th3importedguy
                  • Mar 2014
                  • 190
                  t
                  Yes I always rev match
                  • Doughnut
                    • Oct 2007
                    • 869
                    Ugh, sounds like work son...
                    ///Monstrosity. (OO≡≡[][]≡≡OO)
                    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
