Leaking Automatic Input Seal - Which to replace?
  • ClayW
    • Apr 2011
    • 377
    I've removed the automatic transmission in my 1986 325e to replace a leaking input shaft seal. I have the #6 and #7 seals.
    Should I bother taking everything apart to get to #7? Seems like a gamble.
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • steve68
    • Jan 2013
    • 457
    Right now I'd find some swap parts, and leave that boat anchor on the ground! never been a fan of e30 auto transmissions even when they were new,
    88 M3 Lachsliber glass top, 90 IS project,
    • estoguy
      • May 2013
      • 1087
      I second that!
      Estoguy
      • TobyB
        • 5298
        ...but if you really have to save that autobox, I guess I'd change the big o- ring, too.
        Just because the darned things are so heavy- like you, I'd bet that it's the seal, #6...
        t
        • AndrewBird
          The Mad Scientist
          • 11898
          How is #5 held on? If it's simple, I'd replace it, but if the fasteners are on the backside and a pain to get to, I'd consider not bothering. More than likely it's #6 that is leaking.
          • TobyB
            • 5298
            I think you have to pull the bellhousing off to get cover #5 off- it's been a long time, but
            I took one apart for fun once, and remembered thinking it was odd.
            t
            • steve68
              • Jan 2013
              • 457
              I just pulled the one out of my 90, I picked it up and threw it in the back of my truck, I'd just replace 6, get it back in there,
              • ClayW
                • Apr 2011
                • 377
                Just did #6. No more leaks!
                The big o-ring looked like it would require some serious worked, so I opted out.
                • steve68
                  • Jan 2013
                  • 457
                  good for you, going back to FL on Friday going to try to take mine to the scrapper, along with some other metal,
