correct way to install clutch disc?
  • mr.vang
    • 4371
    I have searched but nothing seem to be clear. This is how I got it installed. By the way, its a single mass flywheel m20b25.
    Thanks in advance
  • mr.vang
    • 4371
    anyone?
    • PKile
      • Apr 2016
      • 184
      That's right. Nearly every disc I've seen is marked "flywheel side" or "gearbox side" on the center somewhere.
      • mr.vang
        • 4371
        It has some German words on it. I'm not sure if that's it or not. It's my first clutch installation so I'm a noob at this. Thanks though.
        Sent from my LG-H631 using Tapatalk
        • NC325iC
          • Mar 2004
          • 6565
          One side of it should be marked clearly with flywheel or gearbox. You do not want to get it on backwards, it does not come off easily.
          • TobyB
            • 5280
            Yeah, that's right- springs go into the cover, not the flywheel.
            Getriebegehäusetreibe or something like that means gearbox side.
            t
            • mr.vang
              • 4371
              Thanks for the help guys. I will mount the transmission today. Hopefully everything goes well.
              • schmidty
                • 1253
                Let us know how it goes, I need to do the same soon
                • Waffle cone
                  • Dec 2015
                  • 153
                  how'd it all go?
                  going to be trying a auto -> manual swap next week... kinda scared, but should be great learning experience :D
                  • mr.vang
                    • 4371
                    Originally posted by Waffle cone
                    how'd it all go?
                    I got the transmission on but I haven't drop the motor in the engine bay yet as I'm still waiting for my e36 steering rack to get here.
                    One thing I did learned when putting the flywheel on, you have to buy new bolts that have sealant on them or used old one and add the thread sealant on. Oil will leak through the bolt if no thread sealant is not used.
                    Overall, it's a good experience and everything went smoothly.
                    • uturn
                      • Dec 2010
                      • 1005
                      That's right about getting the right bolts.... manual flywheel bolts are longer than the automatic's.
