Single mass FW bolts
  • Supratreo
    • Aug 2016
    • 135
    Hi, quick question. What are you guys using for bolts for a single mass FW on a m20? According to realOEM they are disc.
  • Madhatter
    • Oct 2004
    • 966
    Only due to length. The auto bolts are 3mm longer at 28mm and can be used fine; its the same bolt bmw pretty much use in all their autos, right up to the current generation. I think they have simply used the same bolts for both now and discontinued the manual/single mass ones. 11227805885 should help you out if going direct.
    Just a little project im working on
    - http://www.lse30.com -
    • digger
      • Nov 2005
      • 6197
      click on the p/n in real oem and it tells you the p/n that supersedes it many cases
      http://www.realoem.com/bmw/enUS/part...&q=11221717840
      i believe s14 bolts from ARP fit if you get the 28mm length ones not the 22mm....you gotta add your own loctite though
      • Supratreo
        • Aug 2016
        • 135
        Thanks for the help. It also looks like you need that metal spacer so I'm thinking the auto one should work fine? That would also help than A some length off the bolts if I decide to use the longer auto bolts.
        • Panici
          • Dec 2009
          • 2570
          Not sure if it helps, but here is a height comparison between auto and 5-speed gall spacers
          • Supratreo
            • Aug 2016
            • 135
            Huge help, thank you.guessing 5sp is on the right?
            • Panici
              • Dec 2009
              • 2570
              Correct!
              • Madhatter
                • Oct 2004
                • 966
                If you use loctite, be extremely sparse on the application. You do NOT want it to get anywhere near the head of the bolt when its torqued down.
