shifting quirk... need guidance...
  • m3j0n
    • Feb 2006
    • 395
    when the car is off, the car is very easily put into gear and shifted through all the gears. Once the engine is running, however, it becomes super difficult to put it in gear and almost needs to be forced into gear. Any ideas where I should start my search for the culprit? thanks.
    -Jon
  • e30davie
    • Apr 2016
    • 1788
    Your clutch. If its not disengaging fully it will probably give symptoms as you describe.
    Did this start happening after you changed something? has it gotten worse over time?
    • m3j0n
      • Feb 2006
      • 395
      bought the car like that
      • Panici
        • Dec 2009
        • 2570
        +1.
        You can double check this by putting the rear of the car on jackstands. Start the car in gear with the clutch pushed in. If the back wheels are moving at all, then clutch is not fully disengaging.
        Start by bleeding the master/slave system for the clutch.
        If you bleed the system and and the symptoms come back after some time, chances are that there is a leak or torn boot somewhere.
        • nrubenstein
          • 3148
          Yes. This sounds like a clutch disengagement issue. Bleed your clutch properly (with the slave disconnected, compressed, and the bleed screw vertical). Also check the pedal box for cracking. If the pedal box is failing, it'll eventually bend enough that you can't fully disengage the clutch.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • m3j0n
            • Feb 2006
            • 395
            thanks! will check it.. the car had been sitting for quite some time, so its possible that the hoses have allowed some air in the system. fingers crossed that its a simple bleeding issue and not a full clutch job...
            • nrubenstein
              • 3148
              Get your head under the dash and inspect the pedal box. Push the pedal down and watch for any movement.
              • m3j0n
                • Feb 2006
                • 395
                what am I looking for exactly? can this inspection be done without removing the lower part of the dash?
                • nrubenstein
                  • 3148
                  You have to pull the dash panel off. You are looking for any pedal pivoting, or movement of the bracket.
                  • m3j0n
                    • Feb 2006
                    • 395
                    thanks nick!
