Gear fluids I have from other cars can I use them in my 5speed/4.10 LSD?
  • parkerbink
    • Jun 2004
    • 10138
  • TobyB
    • 5298
    yes- the bottles tell you which goes in which.
    Also good for hair styling.
    t
    • parkerbink
      • Jun 2004
      • 10138
      tanks
      • estoguy
        • May 2013
        • 1087
        The 75w90 NS isn't good for LSDs. It's meant for open diffs. Doesn't have any friction modifiers etc.
        Estoguy
        • YosemiteSam
          • Apr 2011
          • 1303
          Get some MTL for your trans and never look back.
          • parkerbink
            • Jun 2004
            • 10138
            This?
            Popular for BMW (before 1993), Honda and Acura, Ford Focus, late-model Mini Cooper, Dodge & Jeep NV 1500, 3500, and 5600
            • kronus
              • Apr 2008
              • 13032
              in my experience MTL and MT-90 are pretty interchangeable, and MT-90 goes into a g260 decently well.
              unsure about your other juice. 75w90 is pretty generic and might be good in a diff. no idea what NS is.
              cars beep boop
              • parkerbink
                • Jun 2004
                • 10138
                I don't remember what car(s) they were for. I also have 2 Redline synth ATF bottles.
                I want to refresh the fluids and figured if I had some that was correct already why buy more.
                Thanks
                • M3 Ryan
                  Site Sponsor
                  • 2298
                  75/90ns good for diff. Use the synth atf in the power steering. Fluid the reservoir every oil change to keep it nice and clean and not oxidized..
                  '88 M3.2 S54 Lachssilber/Black
                  '07 335i Alpine/Black Sedan
                  '12 X5 3.5i Alpine/Black
                  iS Splitters For Sale, PM ME!
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Thanks Ryan.
                    This is the ATF.
                    • M3 Ryan
                      Site Sponsor
                      • 2298
                      Originally posted by parkerbink
                      Thanks Ryan.
                      This is the ATF.
                      Any atf is good for e30 steering, the cheaper the better. If it leaks, use valvoline maxlife with stop leak. It's amazing for sealing up leaky racks/pumps etc for $6.
                      • parkerbink
                        • Jun 2004
                        • 10138
                        Good to know, the last two owners took care of leaks, one put in a e36 rack, new lines & pump and did all the seals, clutch and suspension. Only nigggle is it does not want to run.
                        First I had this:
                        Now this:
                        I wanted a project but this is ridiculous!
                        lol
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Correct.
                          MTL and MT90 are GL-4 (synchro-safe) fluids. MTL is 75w80 and MT90 is 75w90.
                          75w90 is good for the diff, we use it in the endurance cars without issue, 75w90ns will make the diff chatter at low speeds, as the modifiers in it help worn diffs.
                          • Contains extreme pressure additives like our 75W90 GL-5 oil, but lacks friction modifiers to balance slipperiness
                          • Improved copper corrosion protection to prolong synchro life
                          • Helps with lock-up on weak limited-slip differentials-compatible with Red Line Limited Slip Friction Modifier for tuning slippage
                          • Also used with clutch-type LSDs in racing for maximum lock up
                          Most important thing is NEVER use GL-5 in a Getrag or ZF. It is yellow metal corrosive (synchros).
                          john@m20guru.com
                          Links:
                          • parkerbink
                            • Jun 2004
                            • 10138
                            Thanks
