Shortcut for Rear Diff Bushing Replacement?
  • Aleman
    • Mar 2012
    • 1611
    If I want to change my rear diff bushing, can I just remove my diff cover to do the replacement? This would be easier than dropping the whole diff, right? Any precautions I should keep in mind?
    Thanks!
    R135 /// 1990 Alpinweiß II 325is
    └┼┼┘ /// 1993 Black/Black Convertible (sold)
    ..24
  • glnr13
    • 1334
    you need to drop it to clear the big tabs that are forward and aft of the bushing itself.
    you can see here they dropped it just enough to clear the bushing:
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Just pull the whole diff out and reseal it along with replacing the bushing.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Aleman
        • Mar 2012
        • 1611
        Thanks guys - looks like I will still need to drop it some. I plan on send the diff out for a full rebuild sometime next year, but I really need to stop the annoying clunk from the back end in the meantime.
        ..24
        • The Dark Side of Will
          • Jun 2010
          • 2796
          Don't forget to unplug the VSS first.
          • glnr13
            • 1334
            that's for damn sure. don't do what is in the photo I posted despite the fact that it's from pelican parts.
            • TobyB
              • 5298
              why? that's a sure- fire wire stretcher, right there!
              heh
              t
              • glnr13
                • 1334
                i mean don't get me wrong, i love getting my wire stretched if you know what I'm sayin
                • parkerbink
                  • Jun 2004
                  • 10138
                  I have an LSD I bought I have a Garagistic bushing coming for it. I could use a shortcut to get the intact perfect looking bushing out as well as input as to what to do to it prior to install.
                  It sat in a Phoenix storage unit for 10 years should I open it up and change out all the seals?
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    i wouldn't even think about changing the diff bushing without a press. def do the output flange seals, o rings, fluid of course and since the cover has to come off you'll do a cover gasket as well.
                    Input shaft seal requires a little finesse so if it's not leaking I'd leave it be
                    Alice the Time Capsule
