Is this seal install going to cause problems?
  • RenaissanceMan
    • Aug 2004
    • 237
    Just installed a new output shaft seal on my ZF trans and as you can see I have gone past "flush" with the placement of,the seal. Is this going to now be more susceptible to a leak? Or does it not matter since the inner diameter of the housing is not stepped? TIA.
    Sent from my VS995 using Tapatalk
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
  • TobyB
    • 5298
    Wow- you really overperformed, there.
    take a marker and blacken your output flange seal surface.
    Install the flange with a little oil, and spin it a bunch.
    Then pull it, and see if the seal lip's riding on the surface.
    If it is, you're ok.
    If not, you get to do it again.
    Deburr the outer edge of the housing before you do.
    hth
    t
    • RenaissanceMan
      • Aug 2004
      • 237
      Thanks for the reply. Yep, I overdid it, and I should have known better because I've done this job before. That's what I get for working tired. So can I assume from your reply that as long as the seal is actually touching the flange while turning I'm okay? Thanks again -
      '90 325is/S52
      '76 2002
      '74 2002tii
      '06 325i sedan
      '05 X5 3.0i
      • TobyB
        • 5298
        That's my experience- it just needs to ride on the machined surface...
        t
        • e30davie
          • Apr 2016
          • 1788
          It is often common practice to place the seal in a slightly different location to the old seal so that the new seal is running on smooth new steel. It is possible that the output shaft has worn over the years and that what causes a leak...
          However moving it by 2" is not common practice! haha
          • uturn
            • Dec 2010
            • 1010
            He's just living up to his screen name, a true "RenaissanceMan" finding new ways to do things that will lead us into the light! ;)
            • RenaissanceMan
              • Aug 2004
              • 237
              LOL!
              Thanks for the feedback, y'all... It is making very light contact but I ordered a new seal just to play it safe.
              '90 325is/S52
              '76 2002
              '74 2002tii
              '06 325i sedan
              '05 X5 3.0i
