Driveline shudder with new components
  • e30davie
    • Apr 2016
    • 1788
    Hello. Story and question is as follows.
    M20b23, manual conversion by yours truly using a g260 and all that jazz
    1yr - 20,000km ago i performed the following:
    -new clutch
    -machined flywheel
    -new gearbox mounts
    -engine mounts were ok at the time.
    -rubber thing between the gearbox and driveshaft looks pretty new. I didnt buy it but it looks id guess less than a year old. still very firm.
    Started to develop a driveline shudder at a specific rpm at around the 15,000km after above work mark. about 1500-2500rpm under acceleration, it would not shudder before this, it would not shudder after. it was progressively getting worse, but still driving fine.
    I figured it was the centre support bearing. I bought a new one without even checking the old one, an aftermarket one, i cant recall the brand. whatever the generic German brand.
    When i removed the old center support bearing, the bearing and rubber was still in what i would consider usable shape. the bearing was perfectly fine. If anything the rubber was stifffer than the rubber in the new bearing i had bought. If i had checked before buying a new one i wouldnt have bought a new one.
    Since i had it all appart i installed the new centre bearing and rubber anyway. Everything went fine and i put it all together.
    I marked the driveshaft before pulling it apart. it went back the same way as how i pulled it apart.
    Not it shudders worse!!
    Basically it shudders less overall but it shudders basically from about 1500-4000 or even 5000. not sure but it does go away at higher rpm. But its defiantly more than before. its a more high frequency shudder than before perhaps.
    Engine mounts gone maybe? its all that is left.
    Rear cradle bushes i've no idea....probably had it? can this cause this annoying vibration?
    also i know i keep mentioning rpms, but the vibration is definitely speed dependent not rpm dependent.
    Ideas k go!
  • AndrewBird
    The Mad Scientist
    • 11898
    Worn out u-joints on the driveshaft can cause vibration.
    • e30davie
      • Apr 2016
      • 1788
      Ok I am back with more data and still a vibration issue. Car doesn't get driven that much these days....and I work too much away.
      I took my driveshaft out a few weeks back and took it too a driveshaft shop. They said my uni joints were all in fine working order, they did balance the shaft as well. They said it was out of balance but unsure how much. I suspect it was put together wrong at some Stage. They welded on some weights and painted it black and said it was now in perfect working order.
      Driveshaft went back in on the weekend. My installation method was that i loosened the slip coupling. Bolted it to both the gbox, diff and the center bearing. Unsure if the slip coupling actually moved, but once it was all bolted in I did the slip coupling back up again.
      AND IT FRIGGEN STILL VIBRATES!
      I must admit it is considerably better, probably the best it has ever been, almost passable. But there is still a vibration between 2000-3000 rpm. I want zero vibration. Absolutely none.
      Should i try loosen the slip coupling again and see if maybe its the shaft length needs to be slightly shorter? Is there are proper procedure to setting the shaft length post installation?
      Starting to piss me off!
      Engine mounts aren't new, but they are pretty good condition. Certainly aren't broken. I had a look at the diff mount. Looks ok, its probably original but its not in pieces or anything. I do have a new one to go in, but the old one isn't catastrophically broken.
      • TobyB
        • 5263
        You're saying it vibrates at a specific rpm- but in just 1 gear, say, 4th?
        If you're getting consistent vibration at the same engine rpm in different gears,
        it's not the driveshaft...
        As to length, I have had good luck just loosening it, letting it slip to where
        there's no preload, then tightening it back up. On other cars, I've found that
        tension is better than compression- but just a little, like a mm or 2.
        hth
        t
        • e30davie
          • Apr 2016
          • 1788
          It appears to be worse and most prominent in 2nd gear at the mentioned RPMs.
          I will have another go at loosening the slip and making some adjustments and experimenting. Googling around the internet it seems that it might make some difference.
          I might have a better look at those engine mounts...
          • tomstin
            • Mar 2015
            • 568
            A few thoughts, make sure the slip yoke nut and bushing are in good shape and torqued correctly. Did you pre-load the Center Support Bearing properly? How's the alignment of the entire system? I posted a DIY alignment method on the DIY section.
            2004 525i Manual - 1985 325E Coupe Manual
            • e30davie
              • Apr 2016
              • 1788
              I spoke to the driveshaft guy about preloadong the bearing and he definately advised against it. Though i do see it mentioned in regards to bmws.
              What is the proper procedure for preloadong the bearing? And where does it come from? Bentley manual?
              I had never thought about checking the alignment. Who knows how far out mine is. Thanks for the write up. I'll get the string out.
              • jeffnhiscars
                • Jun 2011
                • 6011
                I'm pretty sure Bentley says to preload the bearing and it's SOP IME. I believe it's 1/4" forward but dont quote me. I just know you do it.
                There is also a side to side alignment but I can't say that either adjustment can cause vibration.
                Alice the Time Capsule
                • e30davie
                  • Apr 2016
                  • 1788
                  Hmm cheers. Well not a big effort to try the preload thing as I left the exhaust shield off.. ill give it a go.
                  • beancent
                    • Aug 2014
                    • 12
                    Drive line vibration
                    Could your Guibo be bad. A bad Guibo will cause vibration
                    • e30davie
                      • Apr 2016
                      • 1788
                      • TobyB
                        • 5263
                        The csb should be preloaded a little- 2mm forward? Seems like just a bit's enough.
                        The driveshaft itself is not supposed to be- but again, just a bit of tension
                        has been good to me.
                        If it does it at the same rpms in different gears, tho, it would seem to be engine, not driveshaft vibes...
                        had a pressure plate fail once, and it did what you're describing.
                        t
                        • e30davie
                          • Apr 2016
                          • 1788
                          Ok so i actually dug out the bently last night, found a copy on my laptop. I thought it was at home. Its very clear about the pre-load of the centre support bearing. Couple of mm is all it says.
                          It also mentions seizing of joining spline on the shaft as a potential cause for vibrations. I assume if this is seized up it doesnt allow it to extend/retract if required during installation. it also only specifies 17nm to do it up, which is bugger all, so maybe its not supposed to be done up tight and is allowed to extend/retract during use.
                          They also mention the alignment of the drivetraie (as discussed above) very interesting stuff and it gives somewhere to measure the alignment, ill have to get a bit more serious it seems on the alignment side.
                          I had not considered the engine side of things being an issue as everything is new, however i guess even the harmonic ballancer might be stuffed causing this. Id better investigate all things. It better not be the clutch, I've taken that gearbox out far too many times already. Bloody stupid bell housing bolts.
                          • e30davie
                            • Apr 2016
                            • 1788
                            Right well, i put a bit of pre-load on the centre bearing, took hardly any effort at all, just loosend the bolts, pushed it forward a tad and tightened it back up.
                            Fixed 99% of the vibration. Unbelievable.
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              Funny how the smallest of details can make you crazy but glad you've got it sorted
