ATF fluid
  • lordofthewaters
    • Oct 2005
    • 714
    ATF fluid
    What is the total capacity cooler/lines torque converter and all? Bentley says 3.2 quarts, but that's just drain and fill for the pan right?
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    I would purchase 4 quarts total. After you drain it and change the filter then put three quarts in. Start the car up and let it get warm, run it through each gear, check fluid and add as needed.
    IMHO, if you have the option, dump the slushbox and swap w/ a 5 speed. Automatics make E30s feel so helpless when I drive one.
    • lordofthewaters
      • Oct 2005
      • 714
      I just put a new (used) transmission in it from Rigmaster, so everything was drained. The problem is I've already got 4 quarts in it and it doesn't show on the dipstick........
      As for the 5 speed I was gonna do that, but in the interests of time (as I have only one car, the missus drives the VW) I needed it done quick, so no time/cash consuming swap just yet.
      • Schneider325
        • May 2004
        • 3818
        Anyone know the capacity for a manual trans w/ no label (MT90)
          • 34844
          you have to check it with the car running and in neutral
          • Schneider325
            • May 2004
            • 3818
            I'm looking for a rough amount so know how many bottles to buy.
            • kenika65
              • Aug 2007
              • 1336
              I used six qt of AMSOIL Synthetic Automatic Transmission Fluid.
              1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
              1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
              • SpecM
                • Oct 2005
                • 4531
                if the torque converter is dry is will hold 6-8 quarts
                the 3.2 qrts is just a drain+refill spec
                1989 cirrisblau-metallic 325i
