Corvette C4 IRS Conversion
  • bender
    • May 2004
    • 171
    #31
    yeah thats about all it needs.. but i've been fighting some issues with my ECU. not sure whats going on there, as the car ran perfectly before. only thing that changed in that department was the fuel system. (tank, pump, lines, rail, regulator)
    the aeromotive a1000 pump draws alot of current, and i have it wired off a relay that grabs its power from where my injectors, coils and other stuff do. i'm gonna relocate that (to the trunk) in hopes to reduce the load in that area. its mostly an issue i have during starting so its possible the voltage is dropping too far and my injectors are acting differently that they should.
    i have some other small upgrades i had to make too to the trailing arms (4 link bars). i'll post some pics of that later today after i grab some
    600hp beast
    • lowlightbw
      • Mar 2008
      • 668
      #32
      finally a worthwile post about a BMW! a great read, cant wait to see the finished product!
      www.benjamineliward.com
      • golde30
        • 11464
        #33
        wow, this thread is like a big F*&K you to v8 e30 guys. i would rather have the blown s52 ANY DAY. post some details of your motor build?
        IG: @Baye30
        • bender
          • May 2004
          • 171
          #34
          thanks guys
          motor is
          built s52,
          CP 8.5:1 piston
          manley rods
          MLS head gasket
          GT35r ball bearing turbo
          custom tubular manifold
          thats kinda it really - although i have some ideas from the next one, haha
          i might get back to engine stuff once the suspension is 100% squared away.
          so for some more up to date stuff
          i had a pretty major f up last week - when i was putting the diff cover on (about 3 weeks ago) i was missing a bolt. my garage is a total disaster, so i didn't think much of it.
          well what do you know, i found it
          it was inside the diff
          luckily it didn't do any damage to the internals, just put a small hole in the case
          so i had to tear it all apart, and send out the case for welding (its aluminum)
          came back good as new, and while i was at it i added a bung for an oil drail
          in the grand sceme of things, this only set me back a day or so
          During that same time, i was able to upgrade my 4 link bars to adjustable heim rod ends.
          reason being - these bars don't simply move up and down, they must also move left and right and twist as the suspension goes up and down. With the stock bars and urethane bushings, they simply weren't moving. The car was getting 'stuck' at different ride heights, etc.
          after spending about a week or so on the issue i finally hit up some hot rod forums and talked to some other guys that have done the corvette irs swap. They recommended going to a heim joint, which after thinking about it made perfect sense..
          i've never had these types of joints before on a street car, but figured it was my only choice. so far the ride is extremly smooth
          here is a picture of the new bars
          its hard to see, but there are spacers between the side bracket and the joint - this allows room for full joint movement
          The other problem i've been having was with the motor not running properly after installing the new fuel system.
          today i relocated the power feed and relay for the pump and that made a huge different. I then also did something similar for my coils and the car is running much much better.
          I now need to drive it around a bit and log fuel and adjust my curve, as its running way to run and tends to foul the plugs. but its too damn hot for any more work today - its like a heatwave or somthing
          600hp beast
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            #35
            Sweet goodness. I weep in utter notworthyness.
            • Jean
              • 18228
              #36
              Great job man! More pics of the motor :)
              "During that same time, i was able to upgrade my 4 link bars to adjustable heim rod ends.
              reason being - these bars don't simply move up and down, they must also move left and right and twist as the suspension goes up and down. With the stock bars and urethane bushings, they simply weren't moving. The car was getting 'stuck' at different ride heights, etc."
              This is the exact reason why I am hesistant to putting poly or urethane on trailing arm ends, not exactly up/down movement there.
              • SpecM
                • Oct 2005
                • 4531
                #37
                holy crap that is sickness
                what is the weight of that beast, all said and done?
                If it's under 2800 lbs I will kill myself in shame.
                1989 cirrisblau-metallic 325i
                • bender
                  • May 2004
                  • 171
                  #38
                  car weighed in at 2670 on friday - but there are still some things to go back in. Most likely it will be around 2700 / 2750 max
                  made a little video today
                  600hp beast
                  • golde30
                    • 11464
                    #39
                    holy crap dude, that looks scary fast. cant wait to see some 1/4 slips with vids....
                    IG: @Baye30
                    • bender
                      • May 2004
                      • 171
                      #40
                      haha yeah its a wild ride.
                      bump for the monday peoples
                      600hp beast
                      • Jean
                        • 18228
                        #41
                        Great job! Would love to see a video showing the car outside as well
                        • z31maniac
                          • 17566
                          #42
                          Insane.
                          You are truly a master fabricator. I wish I had 1/10th of your skills.
                          www.gutenparts.com
                          • Yakinho
                            • Feb 2007
                            • 650
                            #43
                            Doesn't look solid enough..... Just kidding... Awesome work man.
                            • JGood
                              • Jan 2004
                              • 7959
                              #44
                              Holy shit. When do I get a ride? lol
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
                              • sl0ride
                                • 154
                                #45
                                i smell stickey...
                                Kick ass job man!!
