Stripped Bolt, ZF trans clutch/flywheel
  • Yayrea
    • Oct 2017
    • 83
    Hello R3v
    Im currently trying to remove my clutch/flywheel on my m52b28 so I can mount it on my engine stand and swap the oil pan and sump. I recently removed my 5 spd zf trans from the m52 and when I was trying to remove the bolts around the clutch plate, the final one stripped on me (pissed). I’ve sprayed PB Blaster and many similar sprays but nothing seems to be helping break this bolt loose. I’ve locked onto it with channel locks and everything to try and break it but it just continues to eat at the bolt head.
    Please any any recommendations on how to get this f**ker off will be greatly appreciated!!
    Thanks
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users like yayrea.
  • roguetoaster
    Biggus Tippus
    • 7830
    So, smashing in a torx driver is where I'd start, then I'd move on to locking pliers plus a hammer, then the same with heat applied and possibly rapid cooling, and finally I'd buy a bolt extractor as those do actually work, at least on hex bolts.
    • Yayrea
      • Oct 2017
      • 83
      Went with option 1 of hammering a torx socket in there. 1/2" breaker bar broke it loose with no issues. Had the torch on standby though lol. Thanks for the input! Now on to more fun
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5616
        IIRC that's an allen head, right? IF so, just get a drill ~7mm in diameter. It will center itself as you drill. Once you get into the actual threaded part of the bolt, you can take a chisel and hammer the head off.
        Most times, in your case, when you remove the clutch plate, you'll be able to remove the rest of the bolt by hand.
        • Yayrea
          • Oct 2017
          • 83
          Yes sir, allen head. Ill keep that in mind as i continue to disassemble this engine. Thank You
          • e30davie
            • Apr 2016
            • 1788
            I recently got one out by using a rotary tool (Dremel with a cutting disc) and cutting the bolt head in half, then using a punch to spin the bolt. Bastard of thing.
            • roguetoaster
              Biggus Tippus
              • 7830
              Woo.
              • uturn
                • Dec 2010
                • 1010
                I'd probably re-install the other bolts to take off the tension then try the vice grips again before cutting a slot to use a big flat head screwdriver before drilling.
