U-joint dust protection o-rings replacement possible ?
  • Xelo
    • Oct 2019
    • 22
    Hi guys,
    Stumbled upon these issues and was curious if there is a way to replace the dust protection plastic rings on driveshaft u-joints ?
    Not looking for u-joint replacement, nor driveshaft rebuilding, just interested in some way or either replacing those rings/orings or some other method of replacing their functionality.
    Thanks !
  • ForcedFirebird
    • Feb 2007
    • 8300
    Not unless you have removable joints. The stock joints are staked in, therefore non-serviceable.
    john@m20guru.com
    Links:
    • Xelo
      • Oct 2019
      • 22
      Yeah, I know that, but the orings are accesible and somehow *might* be replaceable if someone would have found a method for locking them out of 2 separate halfmoon ones or replacing them with lock-type style ones or...... or.....
      • Xelo
        • Oct 2019
        • 22
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          They make cut to length oring kits that include adhesive, so you could maybe glue it in-situ.
          Probably hard to get the oring on there without getting grease all over the face you're trying to glue though.
          I'd probably just smear some RTV on it and call it a day.
          Originally posted by priapism
          Originally posted by shameson
          • roguetoaster
            Biggus Tippus
            • 7830
            If an o ring has had it perhaps it's best to replace the u joint? You can do it if you're handy, otherwise there are plenty of shops out there.
            • TobyB
              • 5296
              It's not an o- ring, it's a formed seal.
              And by the time they go, the bearings are usually contaminated and worn, too.
              Sorry!
              t
