V8 e30
  • JasonC
    Site Manager
    • 14451
    LT1 and T5...dooooo eeeeet!
    Or find a wrecked f-body and get one with a T56
    Originally posted by MA_Turley
    am I going to have to mess with the brakes system at all or will that be fine?
    I think the brake booster may get in the way.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • MA_Turley
      • Sep 2009
      • 20
      I'm assuming that I'd have to get motor mounts made.
      -Ask 'em
      -Tell 'em
      -Make 'em
      Master-at-Arms, Naval Security Forces
      • george graves
        • 19997
        Just make the end plates, and then tack-weld them in the car. It's a PITA, but not un-doable.
        Originally posted by Matt-B
        • 416stroker
          • May 2008
          • 2448
          Why a cast LT1? what is the car going to be for?
          84 318I Delphin RIP
          87 325IS delphin 24v Sold
          89 325 Alpineweiss
          • MA_Turley
            • Sep 2009
            • 20
            just daliy driving, Cost is some what of a factor. LSx motors are (in the words of Richard Hammond) "jolly expensive." An LT1 should be a whole hell of alot cheaper and easier to find.
            -Ask 'em
            -Tell 'em
            -Make 'em
            • 416stroker
              • May 2008
              • 2448
              Ok But there heavy. There good engines though Cheap to mod.
              84 318I Delphin RIP
              89 325 Alpineweiss
              • JasonC
                Site Manager
                • 14451
                Also with the LT1's the ones out of f-Bodys and Vettes are aluminum head engines unlike the ones in the B-body cars that have cast iron heads.
                1992 BMW 325iC
                • MA_Turley
                  • Sep 2009
                  • 20
                  How much more can the LT1 weigh vs the M20? I know it'll be more but how much more.
                  -Ask 'em
                  -Tell 'em
                  -Make 'em
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    LSx is not that insane in comparo. I wouldn't waste time with an LT1, there are more go fast parts out there at low used prices for the multi year LSx as opposed to the short run LT1.
                    • JasonC
                      Site Manager
                      • 14451
                      The LT1 weighs (somewhere around 530) around 100 more lbs then the LS1. But that is with everything on it. The LT1 can be made to run right with LS1's but most people just chose to do the LSx cause its the newest and most aftermarket support out there. And makes good power. Also if you do an LT1, they sound better :p. Although nither engine is "cheap" to mod.
                      1992 BMW 325iC
                      • 416stroker
                        • May 2008
                        • 2448
                        Lt's cheaper than a LS the most expensive parts are the ignition shit and the cam.
                        84 318I Delphin RIP
                        89 325 Alpineweiss
                        • MA_Turley
                          • Sep 2009
                          • 20
                          The LT will be "cheaper" Than the LS, plus easier to find. What about the diff, Will that need to be changed or modified. I would imagine not but I may be wrong.
                          -Ask 'em
                          -Tell 'em
                          -Make 'em
                          • 416stroker
                            • May 2008
                            • 2448
                            I dont know what the final drive of the tremic but you may want to change gearing if the cars going to be a driver. The diff will handle what a stock lt motor has to put out
                            84 318I Delphin RIP
                            89 325 Alpineweiss
                            • Jonsku
                              • Oct 2004
                              • 566
                              I'm assuming that you've to get your car from the factory and not try to start a swap like V8 swap if you don't even have an idea of suitable gearboxes or brake booster setups.
                              It's all been done, most of the swaps tens of times and all the info you need to know is there on the internet..
                              - E34 M5 (x 2) -
                              - E30 V8 Cabrio "Kylpyamme" -
                              - Alpina D10 Touring #33/94 -
                              - E46 318i Touring -
                              - Toyota Hiace 4wd -
